Author Topic: Getting ready for first start  (Read 1122 times)
Offline Hutch
  • 1982 CB650SC
« on: October 07, 2018, 02:59:23 PM »
All I have left is to bleed the front brakes, then first start.  I swapped tanks from stock, the fuel line has a very slight up hill from the petcock to the carbs.  I hoping this isn't any issuer since its only about a 4" run from the petcock to the carbs (see pic below).
Here's my first start procedure pieced together from several posts on this and other forums.
1   Test battery voltage (should see at least 12.4V on a 12V battery).
2   Disconnect plugs
3   Give each cylinder a squirt of oil or penetrant
4   With engine off, kick engine over 30-40 times (3 second increments) to get oil flowing
5   Pull tappet covers  1 and 4 to verify oil flow
6   Start while holding plugs against the engine case to verify spark
7   Temporarily replace plugs
8   Open petcock
9   With engine off, kick engine over 5-10 times (5 second increments)
10   Check flow of fuel to the carbs by opening float bowl drain screws
11   Remove all spark plugs and verify each one is wet with fuel
12   Add fuel through spark plug holes 1 and 4 optional
13   Replace plugs when finished
14   Turn ignition to run
15   Choke full, closed
16   Twist throttle 5 times
17   Hold starter for a few seconds
18   Repeat as needed
19   Idle until the choke is no longer needed (about 30 seconds)
20   TEST RIDE!!!
« Last Edit: October 07, 2018, 03:08:05 PM by Hutch »
Re: Getting ready for first start
« Reply #1 on: October 08, 2018, 07:58:27 AM »
+1
WAAAAAYYYYY overthinking. I've found several times that it may not circulate oil until it fires up. Assuming you've pre-lubed the crank and cam it should be fine if it fires for few seconds before it oils.
