Author Topic: Custom rearsets adjustments  (Read 2721 times)
Offline AlekStooge
  • can't afford cheap stuff
Re: Custom rearsets adjustments
« Reply #25 on: April 29, 2019, 08:44:14 AM »
Actually, I was wrong it goes on one of the other bolts. The spring wasn't staying on the brake hook if it if it was under tension.
Offline DaveBarbier
« Reply #26 on: April 29, 2019, 10:39:43 AM »
No, that IS the right bolt it goes on. You adjust the switch by spinning the plastic nut to get tension. Google pictures of other 550s.
