Author Topic: How bad are these valves?  (Read 5389 times)
Re: How bad are these valves?
« Reply #25 on: November 24, 2018, 11:41:14 PM »
ha ha ha no!!!!I don't #$%* around with tiny rubber suckers and twist back and forth between my palms either,stick some hose in your battery drill,jam it over the valve stem and apply pressure pulling back and also with a finger on the valve head,dont spin the #$%* out of it use medium speed and reverse it for the same amount of time,job done!
Online seanbarney41
« Reply #26 on: November 24, 2018, 11:44:21 PM »
Is that a 650 head?
« Reply #27 on: November 24, 2018, 11:46:54 PM »
no 500/550,i have it for sale.new guide seals and head gasket supplied,ports touched up.
« Reply #28 on: November 24, 2018, 11:52:50 PM »
basically just had the exhaust floor levelled out so you can see the seat clearly,i never do much on the intakes just clean up any obvious casting dags.
Online seanbarney41
« Reply #29 on: November 25, 2018, 12:12:41 AM »
ok, guess I never noticed how finned up the 500/550 heads were
« Reply #30 on: November 25, 2018, 12:28:28 AM »
that's another thing,a lot off the air passages externally have crappy cast break away,leaving half or fully blocked airways,i break them though and tidy them up at the same time,any old damaged fins get cleaned up sharp edges etc,takes a coupla days.
« Reply #31 on: November 25, 2018, 06:32:37 AM »
A tool for valve removal- assembly is rather cheap.
Offline gmog44
« Reply #32 on: July 04, 2020, 11:46:43 AM »
Valves lapped per dave500’s drill method: I am afraid to go too far, although the exhaust valves need more... or is it too late? Replace?
'78 CB550
'72 CB450
« Reply #33 on: July 04, 2020, 02:33:35 PM »
 The 45 degree face is troughed and notably pitted. Replace them. Many Honda OEM valves are soft to begin with.
Offline gmog44
« Reply #34 on: July 05, 2020, 01:07:30 AM »
That’s what I feared, thanks for confirming. Replace them I will.
'78 CB550
'72 CB450
