Author Topic: Dyna s on cb750 f2  (Read 874 times)
Offline 2811sntr
Dyna s on cb750 f2
« on: November 22, 2018, 01:03:01 PM »
Hi i bought a dynatek DS 1-2 for my Honda cb 750 f2 1978 mod. When installing i have a problem. When i connect a 12v test light from the junction of the blue or yellow coil wire i got constant light. It seems like the power to the coil go right tru the ignition coil and out to the dyna s. Is it nessesary to change the ignition coils?
Offline Bodi
Re: Dyna s on cb750 f2
« Reply #1 on: November 22, 2018, 04:02:07 PM »
Battery power goes to the coil directly (well, through the fuse, keyswitch, and kill switch) and the Dyna switches the ground connection to power up the coil. You will see 12V power at the junction to the Dyna wires when the "points" are open. But that's not much of a crank rotation with a Dyna S, you should measure a volt or less most of a turn, going to 12V when the timing marks align. Spark happens just when the ground connection is broken by the Dyna.
If the Dyna is not powered, you will always read 12V there... are you sure it has power?
Offline 2811sntr
« Reply #2 on: November 22, 2018, 10:57:59 PM »
Yes the dyna has power.
