Author Topic: Steel Brake Tube - Stuck  (Read 1452 times)
Offline jakec
« on: December 18, 2018, 09:47:37 AM »
I'm rebuilding the brakes on my 400F, hoping to install SS lines here one day. However I am first painting the bike and this includes the caliper. I cannot get the steel tube off of the caliper, or the section of brake line that it attaches to.
There is a 10mm nut on the caliper end, and a 10mm nut to 17mm nut connection on the brake line end. Both are incredibly tight, and I am finding that the little 10mm nuts would rather round of than start turning.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Re: Steel Brake Tube - Stuck
« Reply #1 on: December 18, 2018, 10:01:42 AM »
Use a flare wrench, rather than a standard open end wrench.
Offline jakec
« Reply #2 on: December 18, 2018, 10:25:46 AM »
I'll see if I can find one of these today. It prevents the rounding off? Thanks!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline low-side
« Reply #3 on: December 18, 2018, 10:36:49 AM »
If you don't plan on reusing the line, you could cut it and use a 6 sided wrench or socket.
Offline innovativems
    • Innovative MotoSports
« Reply #4 on: December 18, 2018, 11:12:24 AM »
Heat and vise grips will get it off
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline jakec
« Reply #5 on: December 18, 2018, 11:38:57 AM »
I had planned to reuse it. I haven't tried anything other than wrenching yet because it was so stuck I thought I might be missing a step or doing something wrong.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline sixthwisconsin
« Reply #6 on: December 18, 2018, 02:36:41 PM »
PB Blaster might help. Spray and let set a little while.
« Reply #7 on: December 18, 2018, 03:06:13 PM »
Nice thing is a replacement price is like $10 bucks through 4into1.com
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Bodi
« Reply #8 on: December 18, 2018, 05:14:53 PM »
Propane torch and "canned air" duster spray can. Heat the area of the fitting with the torch... not melting hot but any remaining brake fluid should be smoking. Invert the canned air and spray the liquid onto the steel fitting where it threads in, that cools it off very fast. Try your wrench again. This has worked for me for several fasteners. You can also use freeze spray - made for removing gum from carpet.
