Author Topic: keithlin jets or aftermarket?  (Read 2287 times)
Offline mathias2803
    • honda sohc owners
« on: April 04, 2019, 10:30:54 AM »
I have heard there is some quality difference between keithlin jets and valves and aftermarket. Also in how they perform. Should I just put back the keithlin parts? Don't know if you can see the logo on the valve, but if you can is that the keithlin logo? Looks like half a star ish. If I should put back the keits, what parts are okey to replace?
I had pods earlier and rebuilt the carbs, but now I have the oem filter and the spark plugs are turning black, idle is not good and the exhaust is black inside.
« Last Edit: April 04, 2019, 10:33:35 AM by mathias2803 »
Offline slikwilli420
  • Master of Disaster
Re: keithlin jets or aftermarket?
« Reply #1 on: April 04, 2019, 10:33:23 AM »
Always use Keihin brass for any replacement parts. The brass never really wears out so no since in replacing just because. Unless you have a leaking float needle/seat, there is no since in replacing them as the Honda ones are expensive.
Offline mathias2803
    • honda sohc owners
« Reply #2 on: April 04, 2019, 10:35:41 AM »
I might be having leaking float since I have noticed gas in the oil. That's with the replacement part
Is this a wearing sign on the needle?
« Last Edit: April 04, 2019, 10:39:56 AM by mathias2803 »
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #3 on: April 04, 2019, 11:02:23 AM »
The Keihin float valves usually are not marked. They do not have a Keihin logo.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline pjlogue
« Reply #4 on: April 04, 2019, 12:14:42 PM »
Unless you kept the fuel needle with its respective valve seat it will most likely leak if they get mixed up.  This is because the seat and needle form a worn pair over time.  The fuel valves can be replace with aftermarket of good quality.  The jets and emulsion tubes are what is very important to keep Keihin.
-P.
Offline mathias2803
    • honda sohc owners
« Reply #5 on: April 04, 2019, 12:53:25 PM »
The pictures are from the old stuff that was in the carb. You are talking about the needle in the picture right? I replaced the needle and float valve from the same aftermarket kit. Think I got the rebuild kit from carpy's.
Well my jets have the Keihin star looking thing logo, the dot over the i in the logo.
These were in the carb when I bought the bike.
Does keihnin still produce the jets and valves?
Sent fra min E5823 via Tapatalk
Offline pjlogue
« Reply #6 on: April 04, 2019, 01:24:15 PM »
If the float valve (which consists of the needle, seat and gasket (or washer)) are from a new rebuild kit you should be OK.  If you have old fuel valves and start mixing a seat from one carb with a needle from another carb is when you get leaks.
-P.
Offline mathias2803
    • honda sohc owners
« Reply #7 on: April 04, 2019, 02:00:11 PM »
-P.
Got it thanks. Then I should be good. Maybe I have a float that is sticky since it is gas mixed in the oil. I will check the carbs tomorrow. Will change the o rings and maybe the needle, perhaps move the clip aswell since the bike runs rich
Offline Bankerdanny
  • Endeavor to persevere
« Reply #8 on: April 04, 2019, 02:48:24 PM »
I had problem after problem with the aftermarket float needles that were in my 550F (installed by the PO, not me). I finally broke down and bought 4 OEM sets (needle and seat). Before I installed them I measured with digital calipers and the aftermarket needles were shorter than the OEM.
Offline pjlogue
« Reply #9 on: April 04, 2019, 03:59:51 PM »
Things to check with the floats are:  Make sure there are no barbs on the brass frame for the floats where it is next to the pivot pin holders and there are no places on the pillars where the brass frame can catch.  Also be sure the floats pivot on the pin smoothly and the pin isn't chewed up and the tang on the float lever isn't dimpled.    Floats should sit on a fat surface so both lobes are even on the flat surface.  When setting the float height it's important to have the float hanging down from the pivot pin and rotate the carb so the float just seats on the fuel valve pin.  You don't want the weight of the float compressing the spring on the fuel valve.
Once you have the float height set this way yoou should check it with the clear tube method.
-P.
« Reply #10 on: April 05, 2019, 05:14:30 AM »
  If you have gas in your oil also make sure your fuel petcock is not leaking through when shut off as a leaker won't help your cause .
Offline mathias2803
    • honda sohc owners
« Reply #11 on: April 10, 2019, 04:05:29 PM »
I have ordered 4 new oem 2.5 seat and needle since the ones I have were aftermarket and 2.0. The pin and float height are all good.
I don't understand why everyone say check float height? How can the height suddenly change itself?
The petcock is new and has been shut off every time since I changed oil. But the gas smell is still very noticeable, especially in the exhaust. I always stank after working with the bike
« Reply #12 on: April 10, 2019, 06:50:26 PM »
Is this a 750? (Looks like the carb parts are...).
Check your jet sizes. If Keihin, I'd suggest starting at #40 pilot jets and #105 mainjets with today's fuels. If the jets are Keyster, #40 pilot is OK, mainjet should be #107 or #110 for the same mixture. Keyster's jets seem to always run leaner than their numbers.
Also: make sure your ignition timing is correct and not advanced a lot. Too much advance causes spitback into the carbs, causing them to run richer than normal.
Offline mathias2803
    • honda sohc owners
« Reply #13 on: April 10, 2019, 07:20:25 PM »
Yes you are right Hondaman, 750 k3.
Pilot is 40 and has a Keihin logo on it(Not installed now) The main is 110. Unsure of the manufacturer, but I will look into it when I'm replacing the float seat/needle. Both Pilot and main currently installed is from a kit I bought from dimecity, remember the package was white and blue.
I have set the timing once, but since it was my first time doing it I will double check!
Also I'm running a 4-1 yoshimura replica from yamiya
« Last Edit: April 10, 2019, 07:26:52 PM by mathias2803 »
Offline mathias2803
    • honda sohc owners
« Reply #14 on: April 11, 2019, 10:58:36 AM »
Timing is good using light method, light goes on exactly on the F mark. Gap in points are.012 / 0.30mm and spark gap at. 028/0.60mm. Looking at the points when running the starter the spark between the ignition points seem weak?
Spark seems to be all over the place and not between the points. This happens with denso plugs and NGK iridium
https://youtu.be/t_3wo5lj_q8
« Last Edit: April 11, 2019, 12:45:18 PM by mathias2803 »
