Did a full bleed with fresh fluid (DOT3) yesterday and removed the bleeder valve. Helped it, but not sure I fixed it entirely. Piston still sticks a bit (but less so) than previously. If it does stick, can be freed by tapping the cylinder bore with your hand so piston is the issue. Maybe it will free up with fresh fluid or maybe it needs a piston kit. Thanks for your help.
