Author Topic: CB500K2 Intake Manifold O-Rings  (Read 1091 times)
Offline Bear Four
« on: May 10, 2019, 09:36:19 AM »
According to the parts list the O-rings for the valve  covers and the Intake manifolds are the same part number 91302-001-020.
They fit the valve covers well, but there's a big gap left on the intake manifold groove. I checked with a straight edge and the thickness of the O-ring is not giving a whole lot of crush.
This was an aftermarket gasket set and I am wondering if the original O-rings were thicker. I removed the originals, which filled the entire groove and still were a bit proud of the manifold flange surface.
Does anyone have a NOS part for thickness reference. The new part is about 2.9mm thick, the old part is similar but fills the groove completely.  Unless these new O-rings swell with use I don't trust them.
Any thoughts or ideas?
Re: CB500K2 Intake Manifold O-Rings
« Reply #1 on: May 10, 2019, 03:59:33 PM »
They fill the groove after being squished
« Reply #2 on: May 12, 2019, 12:48:49 AM »
aftermarket o rings and rubber gaskets always seem to be a bit smaller?
Offline Romhog
« Reply #3 on: December 10, 2021, 08:09:47 AM »
I have come across this same issue. when checking CMSNL.com for example, they say they are the same part as you would use for tappet covers (which is 30.8 mm). When I try one of those o-rings, they look so flush already, I don't see how they will crush. ??? what Am I missing here?
« Reply #4 on: December 10, 2021, 01:37:52 PM »
The OEM part is 3.2mm diameter. There are many substandard parts found in the common gasket kits, so I'm not surprised yours will not fit the intake manifolds. I use mostly Vesrah gasket kits: while they sometimes lasck an O-ring or two, the ones they supply more often fit the OEM specs. If you can't find some in the 3.2mm diameter, PM me, I have some.
Offline Nurse Julie
« Reply #5 on: December 11, 2021, 09:01:49 AM »
They do squish out, I sell them on ebay and fit them to our own bikes, so I know they squish just fine... As long as you use Nitrile and not Viton.
Trust me I'm a Nurse, I promise it won't hurt....much
Offline Deltarider
« Reply #6 on: December 11, 2021, 11:02:08 AM »
They do. So far I had to renew only one.
CB500K2-ED Excel black
