Author Topic: Electroplating or zinc plating  (Read 1065 times)
Offline rocs
« on: May 27, 2019, 07:48:20 PM »
Does anyone have a source for getting their old bolts zinc plated? I searched and saw a lot of people getting it done or doing their own DIY but no professional sources
1975 CB550k's
Offline Airborne 82nd
Re: Electroplating or zinc plating
« Reply #1 on: May 27, 2019, 11:11:45 PM »
Why do you want to use the old ones ? When you can get new ones.
Offline Korven
« Reply #2 on: May 28, 2019, 12:25:29 AM »
Because it's much cheaper. Oem bolts are expensive for original restorations.
Offline brewsky
« Reply #3 on: May 28, 2019, 03:47:10 AM »
DIY is simple, cheap, and, strangely, satisfying!
http://forums.sohc4.net/index.php/topic,160620.msg1845165.html#msg1845165
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline rocs
« Reply #4 on: May 28, 2019, 04:50:34 AM »
A lot of parts you find will be discontinued and nolonger made.
1975 CB550k's
« Reply #5 on: May 28, 2019, 06:33:02 AM »
I’ve been playing for a while. I usually use it for some part that I can’t replace. Fantastic when a part turns out “as new”. Read the threads here and then give it a shot!
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: May 28, 2019, 01:18:41 PM »
If you are in the DFW area of North Texas, I'd recommend Arrow Plating in Ft Worth.  Taken many bikes worth of bolts down there over the years.  Good guys.
