Author Topic: CB550 brake upgrade  (Read 788 times)
Offline Greyhound
CB550 brake upgrade
« on: July 04, 2019, 04:28:29 PM »
77 CB550K
Originally I wanted to just add a second caliper for dual disc setup, and started wondering if there is a worthwhile benefit to just throw on both front calipers from a CB750?
So did some research read that post K3 CB750 calipers will fit onto the 550 forks if also used with 750 brackets and rotors... but, this combo would only fit K1-K2 550’s (is this correct??)
Or will K3-K6 750 calipers/brackets/rotors also fit onto K3 550 forks too?
Is there a worthwhile benefit to upgrading to 750 brakes vs the 550 dual disc?
Thank you in advance for any help.
1977 CB550K3
Offline jaytee-nz
Re: CB550 brake upgrade
« Reply #1 on: July 04, 2019, 04:32:23 PM »
In my experience, the 550 set up is actually better than the 750 in terms of braking performance so I don't think you will gain anything.
Dual discs would be a better option I believe.
Offline Greyhound
« Reply #2 on: July 05, 2019, 02:41:58 AM »
Ah okay, great to hear. Thanks!
So the 550 brake calipers and brackets are interchangeable from left/right, correct? (just not the dust covers?).
Also, what size master cylinder is ideal for dual disc 550 setup?
Thanks again!
1977 CB550K3
Offline jaytee-nz
« Reply #3 on: July 05, 2019, 05:56:04 PM »
There's a "how to guide" here on this forum - go to "Manuals and Technical Documents" and scroll down the CB550 list.
Offline Greyhound
« Reply #4 on: July 05, 2019, 06:18:56 PM »
Found it. Thank you!!
1977 CB550K3
