Author Topic: Reduced ID Muffler. How much is too much  (Read 640 times)
Offline Ace Blackwell
  • 1977 CB550F - Resurrection in progress
« on: July 19, 2019, 11:28:08 AM »
I’m looking at buying a muffler for my 77 CB550F. I can’t find anything with the 52mm / 2”” ID needed. I’m going to use a reducer but got worried that going smaller could restrict the flow too radically.  Is this a concern? Is there a limit to the reduction ( with in reason)?
Also what are the thoughts on DB killers? They sound good in theory but really seem problematic due to blocking exhaust flow.
Ace
1977 CB550F Work in Progress
Offline johans
    • corporate leather
Re: Reduced ID Muffler. How much is too much
« Reply #1 on: July 20, 2019, 04:09:26 AM »
Funny you post this now . I'm going through this at the moment . The pic was just a dry fit on the bike ( w/o reducer ) . I purchased a Supertrapp that needed a reducer that i had made in stainless from a co. in the UK . The motor is a total fresh rebuild ( primary chain-new cam ect...) . Motor starts up perfect , carbs synced ect...  I did have some reversion and some white smoke that always seemed to be there and some popping .. I did the build in my basement and figured the condensation+ rebuild lubes ect.. would burn off . I removed the Supertrapp and everything was perfect , no smoke or popping . I used a set of Supertrapps on a 85 Maserati BiTurbo i built years ago ( i bent and welded my own exhaust ) so i figured i can adjust my back pressure with those mufflers by adding or subtracting discs. It took a weekend to dial it in but it worked great . I think the reduction in diameter would be a problem and some power band would suffer but w/o getting the bike on the road and experimenting i cannot be sure . I was confident i could dial it in ( probably adding a few more discs ) I know this is a ( long ) non answer but it is a good question . I was even thinking of flush cutting the  Supertrapp and TIG welding it to the pipe or sleeving it to that diameter . The ST's do sound nice though. My BiTurbo sounded like a f-16 idling through the neighborhood.
« Last Edit: July 20, 2019, 04:11:36 AM by johans »
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
