Author Topic: 2-3 cutting out issue is back  (Read 752 times)
Offline Bankerdanny
  • Endeavor to persevere
« on: July 25, 2019, 07:53:13 AM »
Right before I left on my trip I experienced the 2-3 cylinders cutting out on my 750F1. I pulled the carbs and double checked the float levels, confirmed my valve clearances, and double checked the timing and point gap.
I thought it cleared up, but then on the first day of my trip it came back. I stopped at a gas station and swapped out the 2-3 condenser for a spare, which seemed to do the trick and it performed just fine for the remaining 1800+ miles I was gone.
Tuesday I decided to ride to work and about 5 miles into the trip I lost them again. I limped into a neighborhoods, parked and took the L the rest of the way (thank goodness for Chicago public transit) and then limped it home.
Last night I swapped in the spare 2-3 coil I picked up on the trip. The bike started right up and was running solid, but after about a block, 2-3 stopped working again.
I am at a loss about what to do here. the fact that it is the pair that I keep losing indicated ignition rather that fuel, but I have replaced all the 2-3 components except for the points. I have 2 spare points setups, so I can swap them, but they are just a mechanical switch, I can't see why they would be the cause of my issues.
I would love some thoughts on how to trouble shoot this.
Re: 2-3 cutting out issue is back
« Reply #1 on: July 25, 2019, 08:14:49 AM »
 These types of problems are a pain, especially since you've done the right things so far. Double check the 12 volt wires and especially the connectors at the points. I found a broken wire in the insulation in a headlight bucket once. It could happen to the points wire. Maybe even make up a jumper wire to temporarily replace the 2-3 points wire?
« Reply #2 on: July 25, 2019, 08:46:04 AM »
Check for points function when it quits.  Points open should have 12V across the them.    Closed points should have zero V across contacts.  The moving arm contact must be insulated from the frame.  Look for a short there. Or a failure of the insulation. Or, try some spare points.
What brand points?  What brand condensers?
Have you cleaned the contacts?  Are you using low ohm coils?
Offline Bankerdanny
« Reply #3 on: July 25, 2019, 09:38:21 AM »
The points and condensers should be the originals, so TEC. My coils are stock and I replaced the plug boots with fresh NGK's last year.
Offline 69cb750
« Reply #4 on: July 25, 2019, 09:40:17 AM »
Points, condensors, coils
Condensors and coils can fail from age, coils can alternate between working and failing when coil is old and heats up.
I have new spares, points plate first, coils second.
« Reply #5 on: July 25, 2019, 01:20:59 PM »
Just about has to be a loose connection somewhere...first place i would check is the black and white wire powering the 2-3 coil.
Remember when we were riding and your bike would shut off altogether?...what did that end up being?
Offline Bankerdanny
« Reply #6 on: July 25, 2019, 01:33:38 PM »
I found a short in the harness that was causing that.
