The SOHC/4 World Tour is in under way.
The tach screw is a simple 5mm button head phillips . My method for removing these is to use a punch sharpened to about a 60 degree point and a small ball peen. Set the point on the side of the head and tap lightly until you got a reasonable divot. Angle the punch to drive the screw counter clockwise. Keep tapping. They usually come out first try but if punch only tears the divot, try again in another location.
