Author Topic: Geared Primary Drive  (Read 49194 times)
Offline Tracksnblades1
Re: Geared Primary Drive
« Reply #250 on: September 11, 2019, 10:04:17 PM »
After initially corresponding with Bear and later with Ramsey chain, this wheel may have already been spoked....
Ramsey has some high speed offerings exceeding 7000fpm. With their engineering department's assistance, perhaps more.
I think Bear had this wheel tried, trued, and blued.
Excepting nitromethane,  the centrifugal force may become a primary concern.
I don't see my plans traveling anywhere as fast as what has already been done.
Age Quod Agis
Offline bear
  • Leeton in Australia
« Reply #251 on: September 11, 2019, 11:50:05 PM »
Just to be clear.
I use the 900cc DOHC cranks, so both cam and primary chains are Morse.
The motor's do not exceed 9'000rpm.
I have never had an issue with torque loads on the chains. The limiting factor was harmonics.
I use a manual primary chain adjuster made by Brent aka Captain and a hybrid cam chain adjuster made by me using a foot also supplied by Brent.
Chains where not my problem.
The weak links for my motors where cush drives and then gears if the cush drive fails.
Having said that I stick to a100 hour lifespan for my motors and then their on the bench for a touch up without fail.
My motor's could not survive running at 12'000rpm+ like Brent's, they are two completely different animals.
Brian
« Last Edit: September 12, 2019, 05:44:48 PM by bear »
« Reply #252 on: September 12, 2019, 10:29:50 PM »
I don't believe Morse's claims either. However, the DOHC's come stock from Honda with a pressurized lubrication system for the chain.
And the 750A's have a pressurized lube system for their chain also.
Keith, please educate me about the pressurized lube systems for the auto and dohc primary chains. I haven't found anything in the Honda manuals so far.
Thanks in advance. :)
Scott
« Reply #253 on: September 13, 2019, 03:59:27 AM »
Scott
Not sure if eBay has an offering for one for a 750a right now.
« Last Edit: September 13, 2019, 04:01:18 AM by Tracksnblades1 »
Age Quod Agis
Online dragracer
  • CB750F Dragbike
« Reply #254 on: September 13, 2019, 01:06:09 PM »
Bear, in a no bar  dragbike street, I think your set up would work fine. I don't think any of us would RIP the cush drive apart as we must using a certain amount of clutch management to launch or bike which does not create heavy shock to the drive line. I'm still very much interested in building a DOHC  crank conversion, Sohc based engine for drag racing. I'll need to look back over some of the old threads whereby you gave some details on how you did the swap.
« Reply #255 on: September 15, 2019, 08:44:39 AM »
 I have an A motor with the top end already removed if anyone needs a peek inside. It's evident a PO had it apart judging by the gooped gaskets so I need to look inside anyway. I too, am watching the progress on the dohc crank swap with interest.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #256 on: September 15, 2019, 12:25:19 PM »
DonR just a heads up JimF was selling gasket kits. Give him a shout.
