Author Topic: 1974 Honda CB 750 carburetor piece  (Read 985 times)
Offline ChangsCB
« on: October 30, 2019, 04:58:18 PM »
Whats up everyone, I been working on this bike for the last year and been putting it aside cause im missing a piece that holds the throttle spring. I've tried looking for a replacement part for it but cant seem to find it anywhere on the net. Does anyone have an idea of what im referring to? ill post some pics of where its suppose to go.
Offline ChangsCB
Re: 1974 Honda CB 750 carburetor piece
« Reply #1 on: October 30, 2019, 05:02:12 PM »
Here’s where that little holder piece I believe is suppose to be.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #2 on: October 30, 2019, 05:04:32 PM »
harisuluv might have one.  he's a member here.
cb750 k6 - ugly
Offline ChangsCB
« Reply #3 on: October 30, 2019, 05:15:38 PM »
Ill have to DM him then maybe, Thanks
Offline Buddhapie
« Reply #4 on: October 30, 2019, 07:12:06 PM »
That is actually just a small piece of flat metal shaped like a pill capsul with a hole in the middle of it to secure your throttle spring, it just sits in between the two center carbs. You can easily make this with a dremel or even a bench grinder, take about 10minutes.
Offline Keith
« Reply #5 on: October 31, 2019, 11:21:52 AM »
Yep, just make one!
Offline ChangsCB
« Reply #6 on: October 31, 2019, 06:01:22 PM »
Thanks for the response. Yes! thats the piece i need. Unfortunately, i dont have those kind of tools.Might just have to come up with something clever.
Offline Buddhapie
« Reply #7 on: November 01, 2019, 03:34:07 AM »
Chang go to a friends house and use their crap lol thats what i do when im in a bind and dont have the right tool for the job, as far as finding the correct flat type metal just look around in ur junk drawer or a hardware store, something like a small door hinge plate or something off an old junky appliance etc would work well to make the part you need... measure the distance and (depth) of the holes in the carb and measure the diameter of the holes and you can make a perfect replica with very little headache... the only the thing that secures this piece is just the two crabs being held together by the backing plate, otherwise it rotates freely in the carb casting holes. They made it so simple it seems like it needs to be more complicated lol
Offline wrenchmuch
« Reply #8 on: November 01, 2019, 05:14:19 AM »
If you do make it yourself make it from a piece of stainless steel. The original was Zinc plated to keep it from rusting.
CB750K1
CB750K4
Offline Buddhapie
« Reply #9 on: November 01, 2019, 05:17:23 AM »
Complicated
Offline Doobie
« Reply #10 on: November 01, 2019, 07:10:25 AM »
I have an extra. How badly do you want it?  ;D
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline ChangsCB
« Reply #11 on: November 15, 2019, 05:42:17 PM »
i want it man, hook it up! How much!? ill DM you
