Author Topic: tight spot in chain and in brake..Indications of???  (Read 1385 times)
Offline my name is nobody
  • I like Pontiacs and Hondas
« on: December 25, 2019, 04:57:22 PM »
Can uneven chain tension and what seems /feels to be a flat spot in the rear drum be related?
No matter what chain or sprocket(s) I try, or brake adjustment I do, I can't get a consistent adjustment to obtain satisfactory/consistent results. for either condition. The wheel looks true, and spokes are tight. Could a somehow bent or damaged hub be the cause?  I also tried different used cush drive rubbers to no avail. the rim was replaced along with new spokes and trued., and current chain is new. I'm stumped ??? ??? The tight spot in the rear brake becomes noticeable once the rear brake is correctly adjusted. Rear bearings have been replaced in the past, and
seem to be ok. Anyone experience these types of behaviour occuring simultaneously and know of the fix?
Thx.....
Re: tight spot in chain and in brake..Indications of???
« Reply #1 on: December 25, 2019, 05:41:08 PM »
 All I can think of would be to put a dial indicator on the hub on either or both sides, turn the wheel and watch for runout.
« Reply #2 on: December 25, 2019, 10:59:36 PM »
Are you jamming the brake on, then tightening axle... that will centre your brake better.
Online bryanj
« Reply #3 on: December 26, 2019, 04:55:27 AM »
WHAT BIKE
« Reply #4 on: December 26, 2019, 05:32:39 AM »
WHAT BIKE
750 k5....sorrry, didn't think it would matter on that one :-[
« Reply #5 on: December 26, 2019, 05:55:07 AM »
Yes, as best as I can. Sometimes the axle wants to "roll" forward crookedly inside the swing arm while I am
tightening the nut. It is necessary to insert an appropriately sized screwdriver thru opposite end of axle to prevent axle from turning while torquing the nut.
« Reply #6 on: December 26, 2019, 07:49:26 AM »
 Yes, you should use a holdback on the opposite end. I'm lucky enough to have parted out some barn/field bikes and have a few totes full of spare parts to try for these kinds of problems.
  I always look to see how far away someone is, it would be so cool to just run over and lend a hand or take a different part to test. Only once has a member been close enough.
« Last Edit: December 26, 2019, 07:56:37 AM by Don R »
Online bryanj
« Reply #7 on: December 26, 2019, 09:22:52 AM »
It matters what bike as the 500 is known for rust getting behind the brake drum and making it oval, never heard of it on any 750 though.
Many answers depend on model and year
Offline Redline it
  • thread killer
« Reply #8 on: January 05, 2020, 08:14:02 PM »
Coincidently i was reading the underseat manual today, 70's cb400f. And according to whoever translated the japanese lango in english made some pretty good points, of which i have never seen before, and surprisingly the condition You describe has normally been present off and on for the past 40 yrs, anyway it said kinks, maybe stretched, dirty or dry links (battery corrosion?) which none of those i have, i hope.
« Reply #9 on: January 05, 2020, 09:30:09 PM »
I haven't had any time with the bike lately. I got as far as removing the rear hub. The plan is to swap it with a
different hub. I dread re lacing the rear wheel.  Will post any improvement if hub replacement helps/changes
behaviour. I've run out of possibilities as what could cause the issue.
