Author Topic: Can You Do This?  (Read 1402 times)
Offline gerhed
Can You Do This?
« on: February 06, 2007, 08:23:01 AM »
Look up & down the track at the same time-I don't think so.
          83 XL600R in CB360 Frame
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Can You Do This?
« Reply #1 on: February 06, 2007, 11:31:38 AM »
Makes me dizzy just looking at it  ;D
Nice shot, what type of lens?
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: February 06, 2007, 01:21:14 PM »
A full-circle fisheye woud be my guess.
Offline gerhed
« Reply #3 on: February 06, 2007, 02:13:22 PM »
Camera was of a type called a Cirkut Camera.
Film moves as the lens turns.
Able to do 360's , 720's  etc.
Offline gerhed
« Reply #4 on: February 06, 2007, 02:21:10 PM »
AHRMA--Daytona
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: February 06, 2007, 03:18:31 PM »
Very interesting. Never saw one before, found this, though I suspect an older one.
http://www.bigshotz.co.nz/cirkut.html
Offline gerhed
« Reply #6 on: February 06, 2007, 04:44:18 PM »
Bob,
The new cirkuts work just like the old ones.
I've built a few cirkut cameras myself.
Here's a shot from what I call my 8x10 Rotary Reflex Cirkut.
360 degrees on 8x10 sheet film
Phil
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #7 on: February 06, 2007, 05:33:49 PM »
I'm not a photographer type, but I had to check it out:
Ya gotta love designs that are elegantly simple.
According to the article, cirkkuts are actually old school.  There's a few good early cirkut photos here
Quote from: SOHC Digger, RIP
'77 CB750k
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: February 06, 2007, 07:06:09 PM »
I'd love to fool around with one for a week or so. I bet you can't drop the film off at your local Wal-Mart though. ;D
Gerhed,
Can you generally describe how you synch the camera movement to the film (advance?)? ???
« Last Edit: February 06, 2007, 07:16:17 PM by Bob Wessner »
Offline kghost
« Reply #9 on: February 06, 2007, 07:38:55 PM »
Can't I do that with my stitch function on my digital?  ???
Stranger in a strange land
Serenity
« Reply #10 on: February 07, 2007, 12:18:39 AM »
kghost try it and post the results, could be interesting :D
Offline gerhed
« Reply #11 on: February 07, 2007, 02:11:35 AM »
Bob,
Sync. of film movement with camera rotation is fairly straight forward.
Start with a circle.
The circumference of the circle is the amount of film moved in one 360 degree rotation.
The radius of the circle is the focal length of the lens.
that's it!
Of course optics reverse the direction that the image is moving when it arrives on the film plane.
And exposures are done through a vertical slit.
As an example:
a 28mm lens  needs about 6 1/2 inches of film movement per rotation.
to Kghost:
Yes,in the digital world, stitching accomplishes the same thing, but it is definitely not the Elegant Solution.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: February 07, 2007, 02:48:44 AM »
It it elegantly simple when you describe it. Thanks for the detail.
