Author Topic: Where to buy round ignition plug  (Read 671 times)
Offline VTCBike750
« on: January 14, 2020, 03:03:29 PM »
I see new wire harnesses and ignition switches for sale with the round plugs/couplers. Does anyone know where to buy just the round coupler? CB750supply and similar places only carry the square ones.
Thanks!
« Last Edit: January 14, 2020, 03:06:06 PM by VTCBike750 »
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline VTCBike750
Re: Where to buy round ignition plug
« Reply #2 on: January 14, 2020, 03:59:13 PM »
Don, Thank you. I've honestly been searching for this for years. Asked on here before too.
« Last Edit: January 14, 2020, 04:41:31 PM by VTCBike750 »
-Adam
« Reply #3 on: January 14, 2020, 06:20:56 PM »
For best results with those zinc-plated connectors: get some LPS-1 (not LPS2, or -2.5, or 3) and put a drop on each one. This will help ensure full connection with no corrosion for the longest possible time. These bullet connectors are rated for 12 amps of current, which is how much the 750 uses on both the Black and Red wire circuit, so they are always running at full-load (redline, you might say...). ;)
