Author Topic: Master cylinder question  (Read 632 times)
Offline ckahleer
« on: January 31, 2020, 02:13:21 PM »
81 CB650
I rebuilt my front brake master cylinder, but still think something is wrong. Connecting a syringe to the bleed valve on the caliper, I cannot force brake fluid into the master reservoir.
Should I be able to back flush the brake system like this?
Offline Bodi
Re: Master cylinder question
« Reply #1 on: January 31, 2020, 08:15:00 PM »
I backflush to eliminate air pockets by removing the caliper, pumping the piston out pretty far but not past the seal, then pushing the piston back in with a C clamp.
Never tried a syringe.
But if it can't push fluid back to the reservoir, the caliper is not working correctly.
Note that the relief port is blocked in the first few mm of m/c travel so you get brakeline pressure. Anything like a wrong lever or sticky piston that doesn't retract fully will cause no backflow.
