Author Topic: Rickman cowl lenght  (Read 854 times)
Offline mazingerzeca
Rickman cowl lenght
« on: April 26, 2020, 02:01:59 PM »
Hi everyone.
I have a Rickman seat fiberglass replica, but unfortunately it has some modifications. The end of it doesn't have the same shape that the original one has, as you can see in the picture. The end of the cowl on mine is totally flat. The problem is that I don't know if it has been shorten or some material has been add. Mine measures 25 cm from where the seat ends to the end of the cowl, but I would like to know if I should shorten it or add something to have the same shape as the original one. Could anyone with a Rickman seat measure it? Also, my cowl doesn't have the notch on the center for the sticker, it is flat, and I've never seen a Rickman seat in person, so I would like to know if that notch is the same width as the one in the tank.
Anyone with a Rickman cowl could measure that?
Re: Rickman cowl lenght
« Reply #1 on: April 26, 2020, 05:50:58 PM »
I’ll take some measurements next time I’m in the shop.
« Reply #2 on: April 27, 2020, 12:12:19 AM »
That'll be great! Thank you.
« Reply #3 on: April 27, 2020, 05:23:44 PM »
Shoot! I forgot! Will do it Tuesday........
« Reply #4 on: April 28, 2020, 09:11:20 AM »
So my seat is 9 3/16” from the rear pad lip, to the start of the taper on the tail. Pad lip to tail light face is 10”. Make sense?
The recess in the top of the seat is 1.5” at the front and tapers consistently down to 1” at the back. The tank recess is a consistent 1.5”, front to back. Need more info?
« Reply #5 on: April 28, 2020, 12:28:47 PM »
Thank you very much!
Doing the maths, mine measures 10" (25,4 cm)from seat lip to rear light surface, the same as yours, so I only have to cut the taper, which was add when the fiberglass replica was made. As for the recess, with these measures I can replicate them on mine.
Thanks for the info, I will post pictures when the modifications are made.
« Reply #6 on: April 28, 2020, 01:02:59 PM »
Glad to help! I do have molds and will be making a new body set, later this year. If you want a new one, let me know. Good Luck, John D.
« Reply #7 on: April 29, 2020, 04:11:24 PM »
Good to know. I hope to repair this one, but in case I ruin it tryng to reshape it, maybe I will need a replica. Thanks for all your help.
« Reply #8 on: April 30, 2020, 05:25:05 AM »
Have fun, good luck.
