SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1980 cb650 pd carb question.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1980 cb650 pd carb question. (Read 794 times)
Jetpilot1
Full Member
on:
May 25, 2020, 11:24:14 AM »
With these carbs, can you remove the slide needle without separating the carbs? If so, what is the procedure? I’m in the process of cleaning, setting, want to make sure proper needle and setting as she is running rich.
Logged
TurtleSnifferII
Enthusiast
Re: 1980 cb650 pd carb question.
Reply #1 on:
May 25, 2020, 01:50:43 PM »
Negative. Carbs must be separated to remove the slides from the shaft going across the carbs and from there you can remove the whole slide and in there is a screw to remove the needles and disassemble.
BTW I should add that the needles on these carbs are not adjustable as the clip is fixed.
Last Edit: May 25, 2020, 01:57:12 PM by TurtleSnifferII
Logged
Jetpilot1
Full Member
Reply #2 on:
May 25, 2020, 08:38:37 PM »
Thanks!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
