For recommended medium ratio when cruising and still get immediate power when twisting?
12.5 temporary ratio during max acceleration.
I have read it on several sites.
Here is one:
https://www.rbracing-rsr.com/rsrgauge.htmScroll down to:
"Widely used 12.5:1 (into the 11.0 range) as a target for temporary acceleration enrichment or a slightly rich full power ratio and or a safe turbo boost target."
I should not want that rich during a steady cruise, not accelerating at all.
Carbs is a compromise, run a little rich to get quick response when open the throttles.
Fuel injection with a data box, throttle sensor and lambda sensor can be adjusted perfect for economic ride and still turn the fuel on during acceleration when throttle sensor show the throttle angle and how fast it change, the program in data box will "understand". Data box adjust the ignition advance too.
Max and min values alarms when exceeded. This is more or less a self adjusting system once dialed in. Std in todays cars
My car got the program adjusted and suddenly the turbo increase torque a lot! Very cheap modification ($300US). (Cat and exhaust 5 times more) The std turbo runs out of air at 5500 rpm during WOT. There are bigger ones, but still OK at lower rpm. Kits with injectors.
Same power increase in an old 1.8L engine with carbs should cost!
I'll see how my K6 will look like when running it on the Dyno. I have adjusted all jets to get a good idle, cruising and best acceleration.
Only needle taper not touched. I could not get another needle improving it for how it ran before. I asked a carb dealer here.
I'll see if it will reach 12.5 during a longer acceleration. Acc pump squirt fuel during 1 sec or 2.
I will not change any jets after the dyno even if result recommend it. If I change it runs worse. I have tried all up and down several times.
Maybe pilot to 1 step smaller as I have tried when other things were not OK
