Author Topic: CB550 crank bearing source?  (Read 788 times)
Offline Flexia
« on: June 28, 2020, 04:28:14 AM »
Rebuild a 550/4 now and would like to replace the main bearings.  Plasigage showed then a little larger .002 but under .003.  Is there a source to buy new main bearings because I have not found one?
My case is stamped CCCBB. And my crank is 11111
From that I should be at 3 Green 2 Brown
Where to purchase the bearings?
« Last Edit: June 28, 2020, 05:14:48 AM by Flexia »
Re: CB550 crank bearing source?
« Reply #1 on: June 28, 2020, 05:34:36 AM »
They only come from Honda there is no aftermarket about. 500 are the same try looking on CMSNL for part number and google those
