Author Topic: Blue Spark On Points? - 1978 CB750F  (Read 1755 times)
Offline cowboycletus
« on: July 24, 2020, 07:49:46 PM »
Hey Guys,
I did a little ignition work today and cleaned/gapped the points and set static time . The points for 2&3 were quite dirty and pitted. The bike starts and idles on three cylinders (missing number #2) but while running I can see a blue spark coming from the point for 2&3. It doesn’t do it on the other set.
Any ideas what this is from? Cheap as they are I figure I’ll just get a new set of points and replace them.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Blue Spark On Points? - 1978 CB750F
« Reply #1 on: July 24, 2020, 08:25:23 PM »
Get TEC points not the cheap ones.
Sent from my moto g(7) using Tapatalk
cb750 k6 - ugly
« Reply #2 on: July 24, 2020, 08:47:09 PM »
Get an entire points plate set directly from Honda. I recommend South Sound Honda online, about $80. The others are all knockoffs, and the condensors are bad, some right from the package new. That's likely what you have now: bad condensors cause a bright blue spark at the points, little/no spark at the plugs, and burned points.
« Reply #3 on: July 24, 2020, 09:18:54 PM »
Awesome advice. I just ordered the assembly you mentioned. Thanks Hondaman!
Hopefully this resolves the ongoing issue of me losing that side of the ignition.
« Reply #4 on: July 24, 2020, 11:49:52 PM »
... while running I can see a blue spark coming from the point for 2&3. It doesn’t do it on the other set.
Where exactly does the spark occur? Could be a bad condenser, but, as it concerns the 2+3 breakerpoints, there's a chance it wasn't fitted cprrectly.
« Reply #5 on: July 24, 2020, 11:54:11 PM »
This isn’t my photo but it’ll work for the sake of the post. The spark happens between the 2 metal “points” for 2&3, as indicated in the photo.
« Reply #6 on: July 25, 2020, 12:28:58 AM »
When sparking is in between the breakerpoints surfaces, it indicates a bad condenser. When the spark is elsewhere, it could be breakerpoints fitted incorrectly.
« Reply #7 on: July 30, 2020, 03:42:06 PM »
Good news! A new condenser did indeed fix my problem of blue spark between the points. However,
After installing the new condenser, re-gapping/re-timing, and installing a new clutch cable, I now have an awful squeak coming from the points assembly area. Frequency of the squeak/chirp follows RPM.
The bike starts at the first touch of the starter and idles well. Oil level is full. I was chomping at the bit for a test ride but I couldn’t make myself do it without understanding what that squeak is and how consequential it may be. Any thoughts?
« Reply #8 on: July 30, 2020, 03:45:02 PM »
I also had the gear shift cover off yesterday to replace the gasket.
« Reply #9 on: July 30, 2020, 07:48:57 PM »
Try lubing the points cam?
« Reply #10 on: July 30, 2020, 08:13:30 PM »
That makes sense and would explain why I could hear the “squeak” while turning the engine by hand. I wasn’t aware of lubing the points cam/pads. Hopefully that fixes it!
Any suggestions on lube? A quick google search has suggested either dry lube or brake grease.
Offline robvangulik
  • Honda Fourever
« Reply #11 on: July 31, 2020, 01:56:53 AM »
why would you use brake grease on points? Brakes hardly move and points go up to 10.000 rpm?
Try points grease. But I suppose everything is better than NO grease.
« Reply #12 on: July 31, 2020, 08:26:04 AM »
I think the grease supplied in those little packs is very similar to high temp dielectric.
« Reply #13 on: July 31, 2020, 01:56:09 PM »
Unfortunately there was no grease included with points/condenser packaging but I put a little dielectric grease on the points cam and that solved my issue. Thanks guys!
