Author Topic: Valve Lapping Tip - No More Chewing Gum  (Read 750 times)
Offline bahia
    • William Bay
« on: October 01, 2020, 05:00:52 PM »
I've heard some people resort to chewing gum to get the suction cup to stick to the valves while lapping.
Being a fine art photographer, and hanging as many photographs as I have over the years, I know of this stuff called "Picture Putty" or "Museum Putty."
It helps keep frames from shifting on the wall. (It tends to happen in California a bit  ;) ).
It's the same consistency as chewing gum, but you don't need to get a sore jaw from chewing so much.
A pack from Home Depot will run you $5.
Wad it up into a ball, and press onto the valve really good.
Works a charm!
"Bruce" - CB500K2 + 197? 550 forks + Honda tank(maybe)
Re: Valve Lapping Tip - No More Chewing Gum
« Reply #1 on: October 01, 2020, 05:36:01 PM »
 That looks like permagum, duct sealer which would probably also work.
« Reply #2 on: October 01, 2020, 06:30:54 PM »
I think Bostix blue tac(or white tac) is the same
« Reply #3 on: October 02, 2020, 08:03:43 AM »
 A mechanic friend helped me out on a 750 head one time and we used his favorite paste with a cordless drill turning very slowly with the valve end chucked up with a stiff rubber tube. Seemed to work well. There was a little technique to it and not a full on hard bore spin job.
« Last Edit: October 02, 2020, 02:52:35 PM by ekpent »
