Author Topic: Late CB750 K0 Mold to Gold, the nugget.  (Read 45443 times)
Re: Late CB750 K0 Mold to Gold, the nugget.
« Reply #425 on: October 05, 2023, 05:57:50 PM »
  My new buddy that has a tire machine and can be bribed with beer, fixed the flat, it balanced back up and spins true. Probably more true than before, we'll see if it handles OK next.
  He also mounted the Metzler block C tire on an A model aluminum rim that will hold up the front of the drag bike frame. That leaves the A aluminum rim set with the big tires that came on the K2 yard sale parts bike recently, they may go on the Louisville bike to replace the 16" hog rear.
« Reply #426 on: March 12, 2024, 08:44:43 PM »
 The yard sale A rims mentioned above are now on the Louisville bike, they're getting new Dunlop 404's tomorrow. The nugget spent winter in the race trailer in storage with the Dragster, the Yamahopper and our golf cart. I rolled it out and put it in the shop today, no battery at the moment.
« Reply #427 on: March 13, 2024, 04:54:04 PM »
Don…. I have an extra set of 1975 GL1000 wheels. They are pretty rough, but the rims would polish up. Do you think they are the same as the cb750A and would they lace into cb750 hubs/ spokes?
Online newday777
« Reply #428 on: March 13, 2024, 05:57:08 PM »
They will both lace up with the correct spokes.
The front is the same size as the 750.
The rear is either 17" or 16" on the wing.
« Reply #429 on: March 13, 2024, 10:18:32 PM »
The rims and spokes are identical between the gl1000 and cb750a
« Reply #430 on: March 14, 2024, 05:40:21 AM »
Thank you gentlemen. I’ll have a closer look. Would make a nice set of wheels.
« Reply #431 on: March 17, 2024, 03:09:01 PM »
 I agree, they would lace up but the rears are 17". A set of A wheels bolt right on.
« Reply #432 on: March 17, 2024, 07:42:10 PM »
I have a few extra cb750 hubs I can polish and with a new set of spoke those GL1000 rims might see the road again.
« Reply #433 on: March 17, 2024, 08:33:37 PM »
Don, are A rear wheels 18"?
Online newday777
« Last Edit: March 18, 2024, 06:15:33 AM by newday777 »
« Reply #435 on: March 18, 2024, 08:27:51 PM »
Ohhh, I get what Don is saying the Automatic rear is 17" but already has a standard chain drive/drum brake hub that bolts right on
« Reply #436 on: March 19, 2024, 05:56:36 AM »
Right! The early ones. I think the later ones had Comstar wheels fitted.
« Reply #437 on: March 19, 2024, 09:37:54 AM »
How long did Honda make the CB750A model ?
Online newday777
« Reply #438 on: March 19, 2024, 11:20:58 AM »
76, 77 and 78.
« Reply #439 on: March 19, 2024, 07:43:19 PM »
76, 77 and 78.
Comstars on the 77' & 78's ?
« Reply #440 on: March 19, 2024, 09:15:50 PM »
 Sorry for the lack of replies, I was tied up with election judging.
 Yes, there are 17" wire rims on the early (76?) auto's, the drum brake is cool with a wear gauge and the swingarm is a bit longer and wider than early K's. It even requires a longer axle with fatter spacers and early looking chain adjusters, except they are thinner. A feller could stuff a pretty fat looking tire under one.
 The 19"x 2.15" A front aluminum rimmed wire wheel uses a 78K type hub without the fins in the middle and a late type speedo drive. Both are an easy bolt-on. I've been able to find them both on ebay and behind a guys garage.
« Reply #441 on: June 19, 2024, 05:49:49 PM »
 I wanted to stretch the nugget's legs a little, but the #1 carb decided to be a little pissy. I put it on the center stand and ran the carbs empty a couple times to get some seafoam in there and tonight it seems to have worked.
 Clean idle and no leaking. I need to slap a plate on this one and the Louisville bike to get a few miles on it.
Offline jakec
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
« Reply #443 on: July 22, 2024, 08:46:20 PM »
 No the A rear rims are 17".
« Reply #444 on: November 01, 2024, 05:19:06 PM »
 The #1 carb is acting up again, I'll take it apart, clean out the float valve check for overhanging gaskets and re-check the float level.
 The throttle has some extra play before it moves the slides, so I ordered 3 new throttle tubes for the single cable and a replacement right control bottom from Yamiya. Yup, they sell just a K0 single pull bottom part of the right control. I also got two sets of grips.
« Reply #445 on: February 02, 2025, 05:08:56 PM »
 I had to look up the name of the painter of the Nugget, I got the set from Mark B who frequents here and the Sandcast Only Owners Club. The painter was Blake Conway who also paints for Vic World. The possible reason the set was for sale was the discussion on whether there were any original gold wrinkle tanks. He was doing a restoration and didn't want to get caught up in the argument, if I recall correctly.
« Last Edit: February 02, 2025, 05:13:12 PM by Don R »
« Reply #446 on: February 12, 2025, 05:02:14 PM »
  Today I turned attention to the Nugget, the throttle always had a lot of slack, more than I could adjust out. It was enough that I needed to double grip it to get started. I thought maybe it was due to the two-cable right control on a one cable rack.
  A while back I got a new "one cable" bottom half of the right control and throttle tube from Yamiya and wrestled them on today. The old screws had straight blade heads although they were metric. At any rate, I now have a proper amount of throttle slack, a one cable throttle bottom half and proper Honda screws.
  The right side is nice and black and the halves match but the left is pretty faded. We'll see how much that bugs me.
« Reply #447 on: April 07, 2025, 12:10:19 AM »
 Today I got the exhaust tips from the CMSNL 341 pipes out and lopped off the inner most tube. I put the tips back on the mufflers but haven't started it since last fall. I'm hoping this will help with the sound and ease up the rattly right side pipe.
 It sounds great with no baffles so I might do a little drilling if I have to.
 I have a friend that buys and sells everything and does appraisals. I need a few 750's to go to good homes. Trouble is, he wants the Rat Race and it's my favorite one.
