Thanks for the replies guys.
So far I have -
- cleaned all harness connections - alternator to reg/rec to battery (including the ones behind the drive sprocket cover)
- Checked stator
-phase to phase - all came up at 0.7ohms
-coils to ground - all open circuit
- all three phases show AC with motor running
-Checked reg/rec
with meter set to diode
-neg lead to +on reg/rec - fwd bias - all 3 diodes read 0.46
reverse bias - all open circuit
- pos lead of meter to - side of reg/rec - all 3 diodes read 0.46
As you suggested bryanj I comared voltage at black and white wire to battery with ignition on (I don't have a kill switch).
Battery - 12.32V (bit low as I have drained it a bit starting bike etc)
- black to ground - 11.65V - diff=0.67V
- white to ground - 10.84V - diff=1.48V
As you can see, both higher than the max of 0.5V you suggested - what does this mean?
At this stage I can only think the reg/rec is defective despite all the diodes checking out.
Perhaps I should order another one and give it a go. It will take about a month or more from the states the way things are now, but it seems the only logical answer.
I am interested in your answer re the black and white wire difference.
Thanks in advance,
