Author Topic: Removing Old, HARD Tires.....  (Read 2038 times)
« on: November 19, 2020, 07:18:30 AM »
A few years ago, I bought a new set of tires and my local “friendly dealer” charged me over $100 to mount tires I bought from them. I already knew I could have bought the tires for $100 less on line, so a +$200 experience!
I bought a set of spoons (really strong, polished, long ones), rim protectors, valve stem lanyard, and a wheel balancing/ rim truing stand (total: about $200). Since then, I’ve been building my own wheels, mounting and balancing new tires, etc.
Yesterday, I had to remove a 15+ year old tire from a nice alloy rim. The shop was cold, and so was the impossibly hard tire. Here’s a really good short cut: fitted a 1” fibre cutting wheel to my high speed Dremel Tool. Using the rim protectors and two tire irons, pop the tire bead over one side of the rim. I cut a two inch wide strip of sheet steel (very thin) and slid it under the bead to protect the rim. Using the Dremel, I cut through the wire cable, buried in the rim. This smokes and stinks, but only takes a minute. The steel cable sparks on the cutting wheel. When the sparks stop, your through. It pops about a 1” long slice in the bead and you can see it pop and spread a good bit. Flip the tire, and repeat on the other side. Lube the beads and proceed as usual. Took about two minutes to pop a tire that would have been impossible otherwise......
Works a treat! Good Luck!!
« Last Edit: November 19, 2020, 07:22:06 AM by BenelliSEI »
Online Kelly E
  • Geriatric Hooligan
Re: Removing Old, HARD Tires.....
« Reply #1 on: November 19, 2020, 07:43:20 AM »
I put a new blade in the fixed blade box knife and cut the tire from bead to bead. Then I lever the bead away from the rim with tire irons and cut the bead wire with the small bolt cutters. I have also used the HF 3" electric cut-off wheel to cut the bead wire. Repeat on the other side and done.  :D
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #2 on: November 19, 2020, 08:00:31 AM »
Kelly..... clever. I’ll try this too, less stink!
Offline wolf550
« Reply #3 on: November 19, 2020, 12:34:03 PM »
when ever I see someone working rebuilding a wheel, it looks impossible for me.
I have a project wheel coming up that I would like to keep close and finish it all my myself (re-lace, true, tire install, etc.)
seeing you the more experienced forum members give positive advice definitely helps to keep me wanting to learn a new skill/s.
keep it up when I am on here asking question after question on it! LOL!
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #4 on: November 19, 2020, 04:26:54 PM »
Wolf..... there is nothing nicer than a well polished hub, fresh spokes and rim, wrapped in a new tube and balanced tire. Especially when you do it all yourself. Take the plunge!
Offline wolf550
« Reply #5 on: November 19, 2020, 06:40:37 PM »
Sounds good. Once I get the first of my bikes sold off, I will start my project thread and see how much help I can get. definitely motivated.
74' CB550 (Sold)
« Reply #6 on: November 22, 2020, 02:40:01 PM »
 Be sure the tire spoons are mirror smooth and use the flat side against the rim.  I got a set of cast steel ones and sanded them smooth on my belt sander.
Offline low-side
« Reply #7 on: November 22, 2020, 04:30:58 PM »
Like Don said, make sure the irons are smooth and I also use plastic rim protectors.  I haven't left a mark on a rim using that combination.  I too cut old tires off rather than try prying on them.  I cut a section of tire out with a cutting wheel and heat things up with a heat gun.  Then I lift the beads on either side and cut them.
Offline Shtonecb500
    • Youtube profile
« Reply #8 on: November 24, 2020, 06:53:49 AM »
this is truth.
« Reply #9 on: November 24, 2020, 08:42:31 AM »
I have had to use a cut off wheel several times.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #10 on: November 24, 2020, 05:04:43 PM »
Ako din
Online HondaMan
« Reply #11 on: December 11, 2020, 07:33:08 PM »
Great tip!
It works well on 1970 original Bridgestones, too...
« Reply #12 on: December 12, 2020, 10:52:25 AM »
We did the 21” front tire on the Trans Alp, Thursday. It was so small and large diameter, thought it might be easier. Wrong! Sliced the tire bead with the Dremel, and it popped right off.
