Author Topic: Billet Crankshafts  (Read 14354 times)
Offline kmb69
Billet Crankshafts
« on: December 22, 2020, 08:57:11 AM »
Making progress. Billet cranks ready for gear cutting.
Re: Billet Crankshafts
« Reply #1 on: December 22, 2020, 09:57:44 AM »
Looking great Leroy!
How about some background for everyone?
« Reply #2 on: December 22, 2020, 10:16:28 AM »
 The counterweights look like counterweights should look like.
Offline kmb69
« Reply #3 on: December 22, 2020, 11:09:05 AM »
Goal: 1 BAD mofo, gear driven, SOHC Automatic
100's of design and engineering hours invested
These cranks are designed to work in gear driven SOHC A's & K's, and gear driven DOHC's, 900 and up
Can be run with or without electric starter
Can be run with or without CB1100D rotor and stator
Straight shot oiling
Requires Hayabusa rods
« Last Edit: December 22, 2020, 11:12:03 AM by kmb69 »
Offline kmb69
« Reply #4 on: December 22, 2020, 11:11:32 AM »
I agree. One of 2 things my crank builder modified from my original design: counterweights to match my rods and pistons and straight shot oiling
« Reply #5 on: December 22, 2020, 12:18:09 PM »
 They are works of art brother. ;)
Offline dragracer
  • CB750F Dragbike
« Reply #6 on: December 22, 2020, 12:47:37 PM »
Whats the stroke on the beauties??
Offline kmb69
« Reply #7 on: December 22, 2020, 01:44:26 PM »
Frankie, I can't tell all my secrets, LOL, but they are a little over stock. DOHC equivalents.
« Reply #8 on: December 22, 2020, 04:00:11 PM »
Are those rod journals larger than the mains???
« Reply #9 on: December 22, 2020, 04:19:59 PM »
Wow, very very cool!
Offline dragracer
  • CB750F Dragbike
« Reply #10 on: December 22, 2020, 04:49:10 PM »
Lol, thanks for the answer. Very nice piece. Looking forward to seeing what you install this work of art into and viewing the results of the effort on a dragstrip. All I can do is drool and support you from the sidelines.
Offline kmb69
« Reply #11 on: December 22, 2020, 05:29:27 PM »
Not necessarily true. You may have to ride this thing. You have the experience and the gonads. I'm too old! LOL
Offline kmb69
« Reply #12 on: December 22, 2020, 05:48:38 PM »
Very observant Sensei!
The journals are designed for 38mm Hayabusa rod bearings and rods. Pretty sure those rods are good for 200+ HP.
It only added 2.7 ounces to the total weight - 38mm vs 36mm x 21mm wide.
The FEA analysis indicated the rigidity of the crank increased significantly. Way more valuable than the cost of the weight.
The straight shot oiling also increased the rigidity significantly.
Offline dragracer
  • CB750F Dragbike
« Reply #13 on: December 22, 2020, 05:48:50 PM »
You've done the hard work.  I'm open  to do my part if it'll help the overall project come together. The whole SOHC and DOHC communities will benefit from your dedication.
Offline kmb69
« Reply #14 on: December 22, 2020, 05:51:35 PM »
Thank you Brent. It's been quite challenging.
Brent, I may be interested in some of your NOS parts you posted somewhere.
Please PM or email me the list if you can.
« Last Edit: December 22, 2020, 05:54:06 PM by kmb69 »
« Reply #15 on: December 22, 2020, 09:19:26 PM »
Keith, what do you mean by "straight shot oiling"? It looks like there is a significant V shaped groove in the journals?
Offline dragracer
  • CB750F Dragbike
« Reply #16 on: December 22, 2020, 09:55:01 PM »
Any idea when assembly of the power plant will begin and will you share the process with us?? What horsepower numbers are you anticipating.?? Yeah, I've got questions.  Lol. Wise choice on using  stock Busa rods. It helps keep cost down due to wide availability of both used, inexpensive parts and brand new rods
Offline kmb69
« Reply #17 on: December 23, 2020, 07:54:05 AM »
Straight shot oiling is one of the latest advances in racing cranks for autos and bikes.
It is claimed to be much stronger than cross drilled oiling holes.
Pictures attached.
Offline kmb69
« Reply #18 on: December 23, 2020, 08:17:21 AM »
Frank, I am peddling as fast as I can. This is all bleeding edge stuff for me, so it's hard to timeline on a calendar.
I am taking the cranks over to Austin to cut the primary and HyVo gear teeth after the first of the year.
They then go back to California for final grinding and Ion Nitriding.
Transmissions are essentially finished except for the primary drive gear that I wanted to wait on the crank gears to insure proper backlash. Got to work out the air shifter control.
Still machining on the cases, cylinders, and heads. DOHC frames are already fitted for the SOHC engines but still need a little work on the rear suspension.
Was planning on documenting the first assembly to some extent. Horsepower? The computer calculated potential is overwhelming for my pea brain. Proof is in the pudding.
Yep, the Hayabusa rods were a no brainer for multiple reasons.
Offline bear
  • Leeton in Australia
« Reply #19 on: December 23, 2020, 05:08:39 PM »
Well! You have been busy. ;D
Offline kmb69
« Reply #20 on: December 23, 2020, 06:39:29 PM »
Hi Brian,
It has been quite a challenge.
Cannot wait to get one assembled.
Merry Christmas!
« Reply #21 on: December 23, 2020, 08:25:00 PM »
 My GRANDPA  was Straight Shot  drilling cranks 70 years ago ... :o
« Reply #22 on: December 23, 2020, 08:58:34 PM »
;D ;D
Online Don R
« Reply #23 on: December 23, 2020, 09:23:28 PM »
 This is the coolest thing I've seen since Mikes billet blocks.  That's an awesome pic Frank.
Online Don R
« Reply #24 on: December 23, 2020, 10:13:36 PM »
 I thought I had read years go Coan racing had done some torque converter work on a 750a. It seemed like they were only able to change clearances and not fin angles. If I remember correctly.
