Author Topic: What air filter housings/boxes are compatible with each other? 78 CB750F  (Read 458 times)
Offline Hunter
I have a 78 Cb750F and I have yet to find an air box specifically for that year and model, but I keep seeing Ks and hondamatics (that I have never heard of) that have similar air boxes, but I do not know if there is anything internal that changes the air flow between them.
Also if anyone knows, bike was running only on choke, but that was with no air filters on the carbs at all. Wondering if it was just way too lean to run without choke or if something is plugged.
Thanks for any help!
« Last Edit: March 01, 2021, 12:38:26 PM by Hunter »
Offline Hunter
For anyone wondering, found the answer.
SuperSport F 1975 year model, black only: 17240-392-000,
superceded by 17240-392-305 (same as early K7 model).
SuperSport F 1976 year model, black only: 17240-392-305.
SuperSport F 1977-1978 year models, black only:
17240-405-315 (same as late 77 and 78 K models).
K1 1971 year model, black only, beginning with frame
1044650 which is the first K1 frame: 17212-300-030B.
K2-K6 1972-1976 year models, black only: 17212-341-000.
K7 1977 year model, through frame 2731019,
black only, with top hose port: 17240-405-305.
K7 1977 year model, beginning frame 2731020,
black only, with top hose port: 17240-405-315.
K7-K8 1977-1978 year models, black only,
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
Where are you IRW?
Not running unless the choke is on indicates dirty carburetors.  I recommend you clean carburetors while replacing Air Box.
I run the air box from an F model (which is the same as on a 78 K7/8 I think).  It has the catch basin to greatly reduce the oil from the breather while eliminating the smoke from cylinder head vent by recycling it into top of air box.  P.O. had butchered the original air box in a useless attempt to improve airflow I suppose.
« Last Edit: March 04, 2021, 02:43:31 AM by markmyodb »
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
