Author Topic: Can a cone or baffle fix this lean-ing exhaust issue?  (Read 893 times)
Offline Autoground
  • 1980 CB650c
« on: March 08, 2021, 03:20:02 PM »
CB650c with Keihin carbs.
I'm currently having to run with my air-fuel mixture screws at 3 1/4 turns out, but my plugs say I'm lean.
I'd toyed with the idea of calibrating the accelerator pump rod, but my mechanic (who I'm miffed at) pointed out that I have an aftermarket exhaust that might be leaning out the mixture in the chamber.
The issue is almost completely resolved by having the screws so far out and I don't want to get into rejetting. I'm hoping a baffle or cone would restrict air flow enough to find a nice compromise on
A pic of my exhaust is attached. Is there a cone-cap with db killer that would fit this?
I'm open to all thoughts. Thanks for intput!
1980 CB650c
Offline Scott S
Re: Can a cone or baffle fix this lean-ing exhaust issue?
« Reply #1 on: March 08, 2021, 04:27:32 PM »
 That exhaust really shouldn't cause a lean condition.
 It looks like the baffle was removable at one time. IF you can get it out, you can try wrapping the baffle with some packing.
 Refresh my memory: on your carbs, is the mixture screw on the air box side or the engine side?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #2 on: March 08, 2021, 07:33:24 PM »
The CB650 SOHC4 often runs with white plugs. It is a lean-burn engine! I have seen very few of them with carbon-fouled plugs. My brother, used to his CB500-4 using a set of plugs every 4k-8k miles (blackened) oft remarked that once a year (10k-12k miles) was too often to change his 650's plugs.
Offline Autoground
  • 1980 CB650c
« Reply #3 on: March 08, 2021, 10:39:44 PM »
I've never had such a lean-burning engine. Maybe I'm being overly cautious, too fearful of melting my plugs.
The screws are on the engine side. They are screwed 3 1/4 turns out, so that should be making it rich.
1980 CB650c
Offline Scott S
« Reply #4 on: March 09, 2021, 02:49:19 AM »
 Yes, if they are on the engine side they are fuel screws, so turning them out adds more gas. Try going in and see if it's better (I think 1.5 was stock).
'71 CB500 K0
'81 Yamaha XS650
Offline Flyin900
« Reply #5 on: March 09, 2021, 05:16:05 AM »
You don't show or say if your running a stock air box/filter or pods, as that will also affect it, if you actually have a lean condition. There is no adjustment to the accelerator pump that I am aware, beyond the factory clearance spec on the rod to the actuator tab .
« Last Edit: March 09, 2021, 05:48:54 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Autoground
  • 1980 CB650c
« Reply #6 on: March 09, 2021, 08:36:20 AM »
Correct, there's no adjustment, but the rod has been ever-so-slightly bent, and that prescribed gap from the rod to the actuator tab is mighty small. I've wondered if slipping out the rod and trying to true it in a vise would solve some low-gear stumbling.
I'm going to go a half turn every day or two and keep acquiring data. Sounds like there's no baffle small enough to go into the current exhaust hole.
1980 CB650c
Offline Alan F.
« Reply #7 on: March 09, 2021, 09:01:56 AM »
I'm humbled in current company, but to me the simple important factors are #1 if you're running pods or stock airbox, and #2 what does that exhaust baffle look like? Is it just an end cap with the rest of the baffle rotted or cut away? Wrapping the baffle has been mentioned, and it's a good idea. Replacement baffles are available (diameter at end of your muffler is the important factor) or mods can be done to your existing baffle to reduce flow and noise if needed.
Not to say the lean nature of a CB650 or fuel screw positions are unimportant, just asking about the simple stuff as it would apply to all bikes.
Offline Flyin900
« Reply #8 on: March 09, 2021, 09:03:06 AM »
Very key part of the potential issue as noted above.
If the carbs are the CV style with the larger heavier aluminum slides, I am pretty familiar with that style. They definitely don't like a pod filter, or even a modified air filter or box.
Offline Autoground
  • 1980 CB650c
« Reply #9 on: March 09, 2021, 09:12:23 AM »
Whoops, sorry I missed this answer.
Yes, stock airbox and stock carbs. To my knowledge, after repeated cleaning the carbs, everything is at stock setting except for the air-fuel mixture screws.
My plugs are white, but the RPMs are slightly slow to return to baseline when let go of the throttle. And I do have those screws way out. So I've got symptoms of rich and lean.
However, there is cause to celebrate, because all of these little things don't stop her from running well enough to hit the highway! This is the first week that I've had this thing running and I've been workign on her for a year-- so I'm very delighted! But there's always something.... :)
1980 CB650c
Offline Alan F.
« Reply #10 on: March 09, 2021, 09:29:57 AM »
Congrats on a runner! How's your fuel mileage compared to what other cb650s are getting?
