Author Topic: Cb350f tappet Adjustment question  (Read 732 times)
Offline Dos
  • Owner of a cb350f
« on: March 27, 2021, 09:38:56 AM »
Hey everyone,
 I have this weird phenomenon when I adjust my tappets. when I put my  .002 feeler it feels very tight if I really squeeze in a .003 and then go back to a .002 It feels so much looser should I just adjust my gap as is or put in the .003 and then go to .002
Offline 69cb750
Re: Cb350f tappet Adjustment question
« Reply #1 on: March 27, 2021, 09:44:10 AM »
You want some friction but not tight.
Offline Dos
  • Owner of a cb350f
« Reply #2 on: March 27, 2021, 09:53:16 AM »
Right I get that and when I put the .002 in there initially it will be tight I can actually pull up on the tap with my fingers and it will become looser the same effect happens if I shove a .003 in there the tap it now is so much looser and the .002 feels like nothing when before there was friction on it
Offline Dos
  • Owner of a cb350f
« Reply #3 on: March 28, 2021, 08:14:43 AM »
It’s hard to describe but I will articulate better.
When first adjusting the tappets I have to use some force and slide my .002 feeler in. It will feel very tight however, if I put a .003 in as much as it can it feels like it’s lifting the rocker arm up alittle so then when I put my .002 in it has a lot more space.
In fact I know this to be true because If I go back and fourth with my .002 after the .003 I can feel the rocker arm clamping down on the .002 and it gets tighter again..
So my question is is this normal?
Should I do adjustments based off of where the rocker arm sits at naturally or when it’s all the way up?
Offline 69cb750
« Reply #4 on: March 28, 2021, 08:20:35 AM »
Check feeler with micrometer if you want.
You want slight friction, not tight.
Offline caluser2000
« Reply #5 on: March 28, 2021, 09:27:54 AM »
When you adjust the tappets for the first time on a SOHC/4 it can be a bit nerve racking if you haven't done it before.. I know it was for me personalty. When i'd finished the first time I double and triple checked the clearances were ok and the adjuster nuts tightened. After about the third time I did them I was a lot more relaxed and at the end just double checked the locking nuts before refitting the caps
Do as 69cb750 stated if you are concerned about the feeler gauges.
« Last Edit: March 28, 2021, 11:09:48 AM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline Bodi
« Reply #6 on: March 28, 2021, 11:07:18 AM »
I put a bend in the correct feeler finger and cut the tip narrower to be able to get in under the adjuster, that made it a lot easier to insert and feel.
Offline caluser2000
« Reply #7 on: March 28, 2021, 11:10:50 AM »
Good stuff.
