Author Topic: 11209-300-000 Plug sealing rubber 8.5mm ! Any resolution  (Read 957 times)
Offline flybackwards
« on: April 09, 2021, 03:21:34 PM »
I see an old thread on this but no real conclusion. This is the seal plug at the end of the cross gallery to the countershaft bearing retainer - it seems to get covered by the shifter cover gasket - I did not take one out when I stripped the motor but checking the parts diagram I found it - no longer available of course - make a substitute one? leave it out? whats the verdict?
Offline david 750f
  • 1976 CB750F
Re: 11209-300-000 Plug sealing rubber 8.5mm ! Any resolution
« Reply #1 on: April 09, 2021, 03:56:10 PM »
Vital Motor Parts sells them, you can buy it individually or part of the engine oil seal kit.
https://www.ebay.com/itm/Honda-CB750-SOHC-Engine-Oil-Seal-Kit-8pc-with-Plug-1969-1976/163365050977?hash=item260950da61:g:sSMAAOSwL49b5j8t
1976 CB 750F
Offline Dunk
« Reply #2 on: April 09, 2021, 06:54:14 PM »
Awesome, I'm glad someone is making these plugs!
