Author Topic: CB400F Conrod numbers mixed up  (Read 736 times)
Offline Papalaz
« on: April 11, 2021, 11:39:09 PM »
Morning folks,
Thanks for adding me to the fantastic resource.
First question: During crankshaft cleaning and checking at the local engineering workshop, the con rods got mixed up and left out of the bags I had put them in.  I have two number, 2 and two number 1.
All markings on the crankshaft have disappeared, so I have no way of telling which weighted rod fits where on the shaft. Does anybody have any clue where to start with a solution for this?
Thanks
Offline caluser2000
Re: CB400F Conrod numbers mixed up
« Reply #1 on: April 12, 2021, 12:15:06 AM »
IIRC crank setings are on the rear end of the bottom engine casing.
« Last Edit: April 12, 2021, 12:17:37 AM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
« Reply #2 on: April 12, 2021, 01:24:56 AM »
The casing marks are for the casing, crank marks should be there if you have not had the crank polished/lightened if you have take it back to the shop and tell them you need accurate measurements of every pin down to 0.001mm.
If the numbers are still on rods for size you can then work out which shells you need(there should be a letter and a number on the rod, one is size one is weight and all 4 should be same weight as they are NOY selected for balance)
