Author Topic: CB400F Air mixture screw  (Read 1250 times)
Offline wildtapholer
« on: May 04, 2021, 05:53:00 AM »
Hi I not sure about where to post everything thing yet but I would think most owners look at this page. I have just done a part rebuild of the carbs and was going to change the air mixture screw as it was in the kit, but the screw on my carbs looks to be plastic with a lug on it only allowing the screw to go one full turn and reading on other posts it gives a standard setting of 2 and a half turns out. I did mess with the screws a bit, but being as they only go 1 turn is there a set point for them, I had to balance the carbs with a set of vacuum gages I bought 20yrs ago when I got the bike running but the carbs were way out of sync and the air screw threw me a bit pic included of the air mix screw.
Offline Kevin
Re: CB400F Air mixture screw
« Reply #1 on: May 04, 2021, 05:56:46 AM »
That little black cap pops off.
You can turn the screw until it bottoms out and then back it out. I have found that 1.5 to 1.75 turns is a good range.
If you dont want to put the caps back on I will happily take them off your hands for a bike I am restoring.
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
« Reply #2 on: May 04, 2021, 06:15:16 AM »
It's good to know the carbs haven't been tampered with in it's 44 years of life then.
« Reply #3 on: May 04, 2021, 06:26:46 AM »
I'm in the process of giving this CB400f a sympathetic restoration this is a pic I took when I'd just wrestled the engine back in the frame,good luck with your resto.
Offline Kevin
« Reply #4 on: May 04, 2021, 07:59:40 AM »
Thanks for the luck, I'll need it.
The bike I am restoring has 171  original miles but it's in rough shape.
I'll take my time and go through it meticulously.
I have a few of them so comparitive analysis will be my best friend ;-)
« Reply #5 on: May 05, 2021, 05:44:36 AM »
If the black caps pop off and are just a cover with a slot in, turning the caps won't alter anything then your saying.
Offline Kevin
« Reply #6 on: May 05, 2021, 05:54:18 AM »
No, the caps fit over the air screw tightly, so when you turn the cap the screw will turn too. The cap is there to restrict how much you can adjust it.
If you pop the caps off (and send them to me ;-)) then you can turn the screw all the way in or out.
« Reply #7 on: May 05, 2021, 10:01:27 AM »
Thanks, nice try I'm a bit further than you probably Kevin with the resto, just sending tank back to a friend I know to get the transfers laquered over, i'm really happy with the out come.
Offline Kevin
« Reply #8 on: May 05, 2021, 10:17:48 AM »
The tank turned out beautiful! I'm also looking for a Candy Anteres Red Left side cover for my US spec F2. The US spec C.A. Red is rare so the left side cover is hard to find over here.
« Reply #9 on: May 05, 2021, 01:48:20 PM »
This is what mine looked like before it went to the painters.
Offline Kevin
« Reply #10 on: May 05, 2021, 09:04:15 PM »
What year is your frame?
 I'm guessing it's 1977 or you wouldn't have changed colors.
Looks like the bodywork was perfect already.
Your painter did a great job!
It's hard to find a good painter here in the USA.
Offline Kevnz
« Reply #11 on: May 06, 2021, 01:50:34 AM »
Just love seeing these pics of classy restorations; keep up the good work. ;)
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
« Reply #12 on: May 06, 2021, 06:29:47 AM »
It was black originally and yes it's a 1977 CB400f don't be fooled by the paint you could see sanding marks under the paint, the paint was curling up and lifting off around the filler cap, they hadn't masked off the filler cap and got paint in the tank and that too was curling and lifting in the tank, had to give it a good rinse out with paint thinners and I think it was painted with rattle cans for the finish it had. My painter does it as a side line and hobby in his garage, needless to say he gets very busy, I bought the correct paint, he lays it on.
