Author Topic: Head shield hardware  (Read 635 times)
Offline beemerbum
« on: May 27, 2021, 04:54:13 PM »
I have just received a set of screws and washers for fastening the heat shields to CB 750 stock exhausts. Each set contains three screws, three flat washers and six fiber washers. This is sort of chicken---- stuf, but what is the correct order parts for each screw. Obviously, the flat washer goes under the screw head. Where do the two fiber washers go? Thanks in advance for your time and interest.
Offline BenelliSEI
  • 1969 cb750
Re: Head shield hardware
« Reply #1 on: May 27, 2021, 05:10:33 PM »
One goes under the screw head/metal washer, the second between the heat shield and the pipe.
Offline beemerbum
« Reply #2 on: May 27, 2021, 06:09:04 PM »
As always, the collective wisdom of the members here is awesome. Thank you
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: May 27, 2021, 06:41:44 PM »
Yep.... but can I never remember my wedding anniversary!
