Author Topic: Piston stopper for CB550  (Read 1103 times)
Offline Erny
« on: May 19, 2021, 03:52:37 AM »
I need to check true TDC, so looking for proper piston stopper.
Can you advice what exact stopper I should look for/buy (ideally link to shop/ebay etc) or specification/dimensions that I can order it to local machine shop?
Ideally if it would fit CB750 too, but priority is CB550(500)
locally I found this one, but no sure for dimensions.. https://www.minibikemania.sk/piston-stopper-14x1-25mm/?gclid=Cj0KCQjw7pKFBhDUARIsAFUoMDbl93xAmorgzVKyd-MXNunVFuEZZOJmXI4etZJmszPIMUmq8PPE7eIaAkSrEALw_wcB
Thanks
« Last Edit: May 19, 2021, 03:56:08 AM by Erny »
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline johno
Re: Piston stopper for CB550
« Reply #1 on: May 19, 2021, 05:29:23 AM »
G'Day, I prefer to use a stopper that has an adjustable length.   Easiest way is to make your own from an old plug you have, break up the porcelain with a hammer pliers, screwdriver etc. Then tap the steel section with a tap and use a bolt that you can screw in / out etc.
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline turboguzzi
« Reply #2 on: May 19, 2021, 07:09:15 AM »
at what that stopper costs, just grab it, looks fine. if not just do it like this pic, protrusion bellow plug body abut 16-18mm, but not critical
unlike johno, i dont see the need for adjustable length.... never adjusted mine...
in any case, not rocket science, I did both stoppers at home, without a lathe or anything...
Offline Erny
« Reply #3 on: May 19, 2021, 11:09:54 AM »
Thanks for ideas, I'll do myself one
