Author Topic: F2 rear M/C Q?  (Read 905 times)
F2 rear M/C Q?
« on: August 16, 2021, 09:51:24 AM »
 I have an F2 rear disc brake, the remote reservoir is pretty dried out and cracked, The M/C it's self is stuck hard.
  What's the best route to redemption, GL1000 master cyl. rebuild kit and a reservoir off of some newer bike? How about the caliper?
Re: F2 rear M/C Q?
« Reply #1 on: August 16, 2021, 11:42:19 AM »
Caliper casting i think is f2 only but internals same as gl.
I fitted one of the cheap chinese rear masters to a cbx550 when seals were not available
Re: F2 rear M/C Q?
« Reply #2 on: August 16, 2021, 12:10:07 PM »
Hey Don....
http://forums.sohc4.net/index.php/topic,187719.0.html
These can be hard to find. Surprised it has not sold yet.
Re: F2 rear M/C Q?
« Reply #3 on: August 16, 2021, 02:11:06 PM »
there are loads of rear master cylinders that will bolt in place including gl1000, you may have to mess around with push rods and/or brake line adapters
Offline samm_j2
Re: F2 rear M/C Q?
« Reply #4 on: August 17, 2021, 09:16:42 AM »
I have a rear brake set up if you are interested in it...
Offline Bankerdanny
  • Endeavor to persevere
Re: F2 rear M/C Q?
« Reply #5 on: August 17, 2021, 05:14:16 PM »
The rear on my F1 is a generic item I picked up off eBay for about $25. It was advertised as a GSXR MC. I had to make a small bracket for the top and a stop nut for the bottom to keep it from rotating. Your F2 has a different bracket, so the install wouldn't be the same.
Re: F2 rear M/C Q?
« Reply #6 on: August 17, 2021, 05:25:00 PM »
although the brackets are different, I think the bolt pattern's for the f0/f1 and the f2/3 are all the same.  I wish I had my f3 stored where I could get some pictures of both.
Re: F2 rear M/C Q?
« Reply #7 on: August 17, 2021, 07:23:21 PM »
Don, don't bother with the F2/3 rear caliper (or front calipers); you can do the two piston caliper upgrade using stock parts like you did on the GL. ;)
http://forums.sohc4.net/index.php/topic,89771.0.html
Offline Bankerdanny
Re: F2 rear M/C Q?
« Reply #8 on: August 18, 2021, 01:46:01 PM »
Since I have one in my garage that belongs to a friend I suppose I could wander down and look.
Re: F2 rear M/C Q?
« Reply #9 on: August 23, 2021, 10:16:13 AM »
 It's good, just gathering info for parts in stock. I'm not building it yet. I have 1985 30mm twin piston 1100 V twin calipers  left over from buying the gl conversion.
« Last Edit: August 23, 2021, 10:21:56 AM by Don R »
