Author Topic: Snapped Spark Advancer bolt in Crank  (Read 2737 times)
Offline MrOuija
« on: August 16, 2021, 05:38:49 PM »
Hello all,
New to the forum, but not to forums. My 550K1 was given to me by someone very close who has passed on to his next life. It has been sitting for a while, but still turned over with the starter and kick. During the past winter here in So Cal, (if there is such a thing here) more than likely moisture crept into the cylinders when I removed the exhaust and seized the engine. Long enough story short, I attempted to turn the crank at the special nut at the spark advance, and snapped it off clean in the crank. I am experienced, and have tools, but due to the sensitivity of the nature, any ideas would be great, before submitting myself to a machine shop. What a noob move. Thanks in advance.
Offline ghostdevil273
Re: Snapped Spark Advancer bolt in Crank
« Reply #1 on: August 16, 2021, 06:35:32 PM »
if was me I center punch it best you can ................5/32" Left hand drill bit......Mmmm may come out with just the bit.....No pressure on it........
If not next step would be use a NO 1 easy out (3/32" to 5/32" is the range for NO 1)
Trust me I been there done same thing :)
1973 CB750k3 Cafe Racer(REbORN is it name)
1973 HD XLCH1000 Sporty kickonly (MayBelle)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #2 on: August 16, 2021, 07:48:54 PM »
Weld a nut to it. It will come out.
Online bryanj
« Reply #3 on: August 17, 2021, 01:49:19 AM »
Thats why the book says DO NOT TURN ENGINE VIA THAT NUT.
A carefull centre punch mark and left hand drill will normally get that out DONT use a standard easyout but you can try sizing the drill so you can tap in a torx screwdriver bit and undo it with that
« Reply #4 on: August 17, 2021, 05:07:24 AM »
 There is a rubber o-ring on the bolt piece that is left in there so it may not turn out quite as easy as some. Some lightweight oil or such may help your cause along the way.
Offline robvangulik
  • Honda Fourever
« Reply #5 on: August 17, 2021, 05:42:23 AM »
The bolt has snapped on the groove, you can see the o-ring in the hole and pick it out before attempting to get the bolt out.
« Reply #6 on: August 17, 2021, 05:46:40 AM »
 Ahh yes - I see it clearly when I blow up the pic.
Offline Alan F.
« Reply #7 on: August 17, 2021, 06:01:16 AM »
I haven't had to extract a broken bolt yet, more from being lazy, paranoid or preoccupied than actual wrenching. (Lots of unfinished projects)
Where are good left-handed drill bits purchased?
I may have to pick some up before it happens to me.
I'm in the US but I'm sure Canadian and UK answers will be useful for lots of members as well.
Thanks.
Bummer about your advancer bolt MrOuija, I wish you easy success removing and replacing it.
Offline Geoff Hastings
« Reply #8 on: August 17, 2021, 07:54:51 AM »
A set of hinge drill bits will help keep the drill central, once you have a hole established then I’d try the left handed drill bits.
Offline Little_Phil
« Reply #9 on: August 17, 2021, 07:56:45 AM »
No O ring on the 550, it's just a straight M6 x 55 bolt.
Offline MrOuija
« Reply #10 on: August 17, 2021, 08:08:10 AM »
No O-ring on this bolt is correct.
Thanks all, I will try the easy out method first as stated by @ghostdevil273, and will give an update once completed.
Online bryanj
« Reply #11 on: August 17, 2021, 08:18:52 AM »
DONT use the tapered easyouts as they expand the bolt into the thread and make it tighter
Offline MrOuija
« Reply #12 on: August 17, 2021, 08:26:31 AM »
I was planning on getting some of these, or is there a better recommendation out there?
Offline MrOuija
« Reply #13 on: August 17, 2021, 04:42:25 PM »
Good news,
I drilled a small 1/16 pilot hole, then a 3/32 size bit, followed by a really small flat blade screwdriver and light hammer tapping. She came right out.
Offline Alan F.
« Reply #14 on: August 17, 2021, 07:15:59 PM »
That is good news, congrats on the win.
« Reply #15 on: August 17, 2021, 09:03:39 PM »
Good job!
I love it when patience wins, she is SO cool. :)
« Reply #16 on: August 18, 2021, 02:06:46 AM »
Glad you got it out OK. Another point to make about Ez-outs, don't buy cheap ones or those made in China. Better to spend the money on Snap-On or other professional grade one if you go that route. But, you will find a good quality Left Hand drill bit set is far better investment and tool when dealing with sheared/broken fasteners. If you break a drill bit you have a chance of drilling it out, a hardened steel Ez-Out is nearly impossible to easily defeat because it is so hard.
Congrats on the success.
Time to download the Honda OEM Factory Shop Manual and read it again. Haynes and Chilton are OK references but I don't trust them to be always accurate nor best.
« Reply #17 on: August 18, 2021, 05:50:06 AM »
Glad you cleared that hurdle and I learned something about 500/550 also. Any luck on getting it unstuck yet ? What have you put down the spark plug holes to help ? Be careful if and when it breaks loose as it can make a mess as some here can attest to. Good outdoor job. Maybe rocking in gear like 4th can help break it loose or find the big nut on the other side of the engine.
Offline MrOuija
« Reply #18 on: August 18, 2021, 06:15:31 AM »
I poured some Marvel Mystery oil down the sparkplug holes, hoping it helps. I will try your fourth gear method, not sure I want to try turning any more nuts again.
« Reply #19 on: August 18, 2021, 07:10:53 AM »
 There's kind of a running joke/contest of who has the farthest squirt out the spark plug holes when the engine breaks loose. I think member Steve'o may hold the record.
Online bryanj
« Reply #20 on: August 18, 2021, 07:39:01 AM »
Its safe to use the bolt that holds the alternator rotor on, just dont try starting the engine with the generator cover off
« Reply #21 on: August 18, 2021, 07:44:17 AM »
Yes sir!  17' of the ATF/Acetone "Cocktail" from my K7!
« Reply #22 on: August 18, 2021, 07:55:05 AM »
Great news, patience pays off
« Reply #23 on: August 18, 2021, 08:18:10 AM »
 Thanks for the report, often we never hear how it was resolved.
« Reply #24 on: August 18, 2021, 09:12:32 AM »
Acetone and ATF mix (50/50) does a great job with time getting rings and pistons to release from cylinders
