Author Topic: Stator wire ? 78 cb550  (Read 1292 times)
Offline gbal06
« on: September 15, 2021, 06:51:19 AM »
Do the green and white wires of the stator and coil connect to their respected color (which I assume they should) or does it need to be green/white.  Thanks
Offline gbal06
Re: Stator wire ? 78 cb550
« Reply #1 on: September 15, 2021, 07:08:46 AM »
Also is the green wire with the barrel connector ground?  Is there any trick to get the screw out of the oil switch so I can connect the blue wire?  When I try to unscrew it to remove it, it just spins. Thanks
« Reply #2 on: September 15, 2021, 07:16:12 AM »
If the screw is spinning the switch is toast as the stator/fiels wires they connect colour to colour intothe loom
« Reply #3 on: September 15, 2021, 09:37:45 AM »
Stator wires are yellow.  Field coil wires are white and green.  Match color to color when connecting.
Offline gbal06
« Reply #4 on: September 15, 2021, 10:58:59 AM »
And the green wire with the barrel connector?
« Reply #5 on: September 15, 2021, 12:44:45 PM »
If that is a replacement for the original green with red stripe it goes to the neutral switch
Offline gbal06
« Reply #6 on: September 16, 2021, 06:46:39 AM »
its a rebuild from ricks motor sports.  How does it hook up to the neutral rotor? Thanks
« Reply #7 on: September 16, 2021, 07:59:43 AM »
The terms you are using is confusing.
Restate  your question.
Are you aware that a green wire and a green with red stripe wire serve different functions?
The dynamo rotor has no connections.
The field coil makes the rotor into a magnet.
The rotating magnetic field creates power in the stator which gets rectified into voltage and current which the bike and battery can use.
« Reply #8 on: September 16, 2021, 08:30:11 AM »
I did not say rotor i said switch
Offline gbal06
« Reply #9 on: September 16, 2021, 09:18:45 AM »
The stator was rebuilt by Rick's so I am just trying to confirm the placement of the green wire with the barrel connection shown in my picture. bryanj the part pic on cmsnl (#15) states it as the stator,neutral sw. Is that incorrect?
« Reply #10 on: September 16, 2021, 12:33:03 PM »
Yup, the rotor is a seperate part on the end of the shift drum
