Author Topic: Reground cam off center!  (Read 2921 times)
Re: Reground cam off center!
« Reply #25 on: January 25, 2022, 05:36:29 PM »
I've used the 126-00 in several CB550 engines. All have been fine and have run for years, now, with no issues. Some of them were noted here in build threads. One received the 'big bore'  605cc pistons, the others were stock (0.5mm) overbore pistons. All of them are 10k RPM engines now.
« Reply #26 on: January 25, 2022, 08:33:28 PM »
i always adjust each valve individually,its the only sure way to be sure.
« Reply #27 on: January 26, 2022, 03:35:40 PM »
That is certainly an option.
Offline bistromath
« Reply #28 on: January 26, 2022, 04:25:22 PM »
Mike, have you ever seen a cam like this before, with the clearance varying across the base circle? Just want to get a feel for whether I should consider it normal or not.
'75 CB550F
« Reply #29 on: January 26, 2022, 09:34:19 PM »
 My K/H cam is lashed at .004. I never checked it at less. I also do the EO/IC method of checking lash. I just watched a video on it from Steve Morris race engines that may make me even more consistent adjusting our race car.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #30 on: January 27, 2022, 04:49:32 AM »
If the issue was inconsistent, like you said, impacting only some of the lobes.  Then its a problem with the process.
Could be something silly like the forklift passing by.  Causing a momentary flex in the floor.
Purely speculation..
Either way, it wasn't enough of a defect to make the machinist go "awww sh--"
« Last Edit: January 27, 2022, 05:22:00 AM by BomberMann650 »
« Reply #31 on: January 27, 2022, 11:38:36 PM »
that fixture adaptor tool must be solid,not just 3/16 thick,a tiny flex at one point will throw it all out of spec with the toughness of valve springs.
« Reply #32 on: January 28, 2022, 07:55:54 AM »
I don't recall seeing your problem. I wonder what equipment was used on your cam.....I have a feeling it wasn't CNC
Offline bistromath
« Reply #33 on: January 28, 2022, 11:08:11 AM »
Nope. Definitely an old-school cam grinder. I wonder if his master was off.
'75 CB550F
