Author Topic: 1970 CB750 KO High Idle  (Read 1258 times)
Offline JohnK3
« on: December 04, 2021, 09:37:57 AM »
My 1970 CB750 KO with about 14,500 miles has been running well. It's the model with an individual cable to each carb. A little hard to start, but when warm idled nicely and pulled strongly.  On my last ride, it suddenly started to idle at 3,000 RPM. It still pulled strongly, just idled high.
Any idea what could have caused such an abrupt change?
« Last Edit: December 04, 2021, 09:39:59 AM by JohnK3 »
70 CB750K
71 CB750K
78 Suzuki SP370
81 CBX
91 BMW K75RT
16 Suzuki DR650
Re: 1970 CB750 KO High Idle
« Reply #1 on: December 04, 2021, 12:50:14 PM »
Carb imbalance.  Or cable wear.  Or, needs cable lube.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: December 04, 2021, 01:46:32 PM »
Pop the rubber ends off the cables, where they enter the carb tops. Occasionally, one cable will pop out of the socket (the metal cable ends jumps out of the adjustable socket on one of the carbs). Even one held open will get the idle up there!
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: December 04, 2021, 01:51:42 PM »
Next.... try wiggling the carbs in the intake manifold rubbers. If the idle changes make sure all the clamps are tight. Any cracks in the rubbers?
Also..... a sticking advancer (slow to mechanically retract to idle speed advance)will also hang the idle.
P.S. nice bike!
Offline 2wheels
« Reply #4 on: December 05, 2021, 05:29:49 PM »
Be sure to check all 4 spark plugs, looking for the (way to) white one.
Meaning you have an air leak.  Not as likely as a stuck throttle cable but deadly to the motor if it is.  So worth checking first.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline JohnK3
« Reply #5 on: December 06, 2021, 08:06:16 AM »
Update:
I removed the fuel tank and wiggled the throttle cables to seat them in the carbs, and now it idles fine. It's possible one was off it's seat and causing the high idle.
Thanks Benelli.
70 CB750K
71 CB750K
78 Suzuki SP370
81 CBX
91 BMW K75RT
16 Suzuki DR650
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: December 06, 2021, 01:30:50 PM »
That is one great photo!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: December 09, 2021, 01:29:05 PM »
Update:
Thanks Benelli.
John...... Excellent! Easy fix is always the best. If that outer cable seems a bit loose in the socket, loosen the jam nut and unscrew it a bit, so it won’t happen again.
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: December 09, 2021, 01:31:09 PM »
Taken by a professional photographer, with a real camera. Amazing detail. He did my F and the Benelli too.
