Author Topic: Found a 750K0 cam, opinions please.  (Read 3226 times)
Offline Alan F.
Re: Found a 750K0 cam, opinions please.
« Reply #25 on: January 09, 2022, 10:08:13 AM »
I found a great 754 quote along the way:
It's starting to look like you don't know how much to tighten stuff...
Wait a second, aren't you the guy that had things falling off?
I am starting to see a pattern here.......
« Reply #26 on: January 09, 2022, 03:12:01 PM »
The A cam was designed to work with tiny carbs and intake ports.  The idea was to maximize intake velocity(as opposed to volume) for better low end torque at the expense of lots of top end power.  So yeah, you will probably would get a nice off the line feel but it won't rev to the moon like a good cb750 should.  You end up with sort of a mechanical "conflict of interests"...unless you intend your 750 to perform farm duties or tow some big cargo.
Offline Alan F.
« Reply #27 on: January 09, 2022, 07:48:41 PM »
(Smiling) Thanks Sean, I appreciate your explanation. It might be a fine cam to use if building a 750 engined piece of equipment, but probably not a bike then.
I'll file that away, never know when I'll need it.
Offline Alan F.
« Reply #28 on: January 12, 2022, 02:12:00 PM »
Cam arrived today, I'll be measuring it soon.
Offline Alan F.
« Reply #29 on: January 12, 2022, 03:35:39 PM »
Bearing surfaces:
Offline Alan F.
« Reply #30 on: January 12, 2022, 04:09:32 PM »
First run thru with a dodgy Vernier:
Offline Alan F.
« Reply #31 on: January 12, 2022, 04:14:15 PM »
Markings:
Offline Alan F.
« Reply #32 on: January 12, 2022, 04:38:29 PM »
I was a little thrown by the order of the cam lobes intake and exhaust, I'd never considered it but design-wise it's one good way to make everything fit together in a confined space.
« Reply #33 on: January 13, 2022, 07:20:56 AM »
I took these measurements on several stock cams including my original purchase Yoshimura Daytona cam and I swear the heights are identical with one exception - my original low serial number F exhaust lobe is 0.1mm taller than all others. I was very surprised. I only know for sure one came from a K8 engine and one came from my F0. The others??? Timing? Lobe centers? I did not measure them on the engine.
« Reply #34 on: January 14, 2022, 03:05:49 PM »
Yeah, I always smile and shake my head when I see this page with its measurements from an ideal sandcast engine. When I was measuring lots and lots of these cams (in the 1970s) it was very rare to find one with an intake height of 1.411", as spec'd. Most of them were in the 1.398"-1.405" range, brand new or less than 1000 miles, for the intake lobes. The exhausts were usually close, though.
More important was/is the duration and overlap numbers. These are not so easy to measure: the simplest way without a fancy test rig is to use the engine itself, when assembled (and turn the alternator bolt, please, so you don't bend the spark advancer's shaft) and a degree wheel with a dial indicator on the rocker tip, set to 0.000" clearance. The F0 and later engines use a 0 degree BTDC intake opening (at 0.002" valve lash) while the early engines used 5 degrees BTDC. This became less by the K3, usually around 3 degrees.
« Reply #35 on: March 22, 2025, 02:16:58 PM »
Following
Offline Alan F.
« Reply #36 on: March 22, 2025, 02:59:54 PM »
Eventually I'll get these same measurements posted from my K3 and K8 cams for comparison.
Offline M 750K6
« Reply #37 on: March 23, 2025, 02:38:18 AM »
On K1 to K6 cams, is there a common view on what the spec or min range could be? I ask because when I replaced the damaged head on my K6, I was on a budget. My original (40,000 mile) cam looked smooth and an even colour, but was less than the measurements on that workshop manual page. I re-used it and it seems fine, 2,000 miles later. But, it's one of the things niggling away in the back of my mind.
