Author Topic: Air screw needle O rings???  (Read 591 times)
Offline timtune
« on: February 08, 2022, 02:47:26 PM »
Just finished cleaning and rebuilding my carbs (external control) for a CB750F. All the air needles had a spring but no O ring. My bike was running fine with the carb as is before I cleaned it.
Just noticed Vintage CB750 sells replacement Air screw needle O rings. Whats the deal?
Re: Air screw needle O rings???
« Reply #1 on: February 08, 2022, 03:45:26 PM »
If its a 1975-76 750F with round top carbs they don't have o-rings. Not sure on the 77-78 pumper carbs.
Offline timtune
« Reply #2 on: February 08, 2022, 04:26:00 PM »
Thanks. By "round top" do you mean the ribbed round nut that holds the slide in? Those are the ones I have.
Offline david 750f
  • 1976 CB750F
« Reply #3 on: February 08, 2022, 09:57:22 PM »
Timtune, you need to post the model number of your carbs. They may not be original to your bike, all the carbs have a model number on them.
1976 CB 750F
« Reply #4 on: February 08, 2022, 10:18:44 PM »
Only the bikes with PD carbs need o rings on the idle mixture screws.
« Reply #5 on: February 09, 2022, 05:29:59 AM »
 If they look like this they do not use any o-rings there.
