Author Topic: In-line light to oil pressure wire  (Read 547 times)
Offline mr.brandon
« on: April 24, 2022, 06:28:04 PM »
Hello, I was wondering...I have a 1974 750 that i am now wiring in a bobber frame.. if I attach an In-line light to oil pressure wire then... route that wire to a +12volt source... will that light work and function as my oil pressure warning indicator?
Offline kerryb
  • Not a very
Re: In-line light to oil pressure wire
« Reply #1 on: April 24, 2022, 07:59:47 PM »
Yes, I believe so.  The oil pressue switch is to ground when oil pressure is too low.  So, 12 volt+ to one side of light, other side goes to oil pressure switch (sender)
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: April 25, 2022, 05:17:22 AM »
+1 to that.
