Hi, I have a problem with cylinder number 1.
All other cylinders get hot, while number 1 is still cool, it only starts to heat up when the engine revs up.
I have the compression at all cylinders...
I think number 1 cylinder is not idling,
the spark plug is not flooded, the spark is strong.
Compression on all cylinders is ok.
Carburettors cleaned, jets clea, approx.
Ignition timing and valve is ok.
Any suggestions?
Regards
