Hey all,
I know this has been pretty extensively covered on the forums in the past (I've read nearly every thread I can on this topic), but I was hoping to maybe get some others thoughts on this issue in case I've overlooked something.
I'm helping a friend restore his 1977 CB550 with PD carbs, and it's 99% complete aside from the fact that the idle constantly hangs. The bike fires up and runs beautifully on all 4 cylinders. It'll idle perfectly fine until any throttle is applied. If I've got the bike idling at 1400rpm as an example, but rev it to 3k, it'll slowly climb down and stick around 2k and not return to 1400. This happens no matter what the idle is set to.
Bikes specs and what we've done below:
- Carbs have been cleaned and inspected multiple times. Everything is to spec and nothing is blocked/plugged.
- Stock airbox
- 4 into 1 exhaust
- Brand new spark plugs
- We've tried both the stock points and a PAMCO electronic ignition. Issue persists.
- Battery is new and charged
- Checked intake and head for leaks multiple times to no avail
- Throttle is not sticking. Have done tests with the cable disconnected and operating by hand.
- Slides all move freely, no warping or debris inside carb
- Carbs have been synced
- New intake boots
- Tried idle mixture screw at .5 turns all the way to 5 turns out. Issue persists.
In my mind, it points to an air leak, but we've checked diligently multiple times and have yet to locate any. I had also thought that maybe one of the slow jets was plugged, but we pulled those last night to inspect and clean and found nothing. I had also read in another post that it could be running lean on the idle circuit, but we tested with the IMS backed out 5 complete turns and it didn't fix it. Like I said earlier, the bike starts and idles beautifully....until you rev it. The idle also won't return to where it was set if you let it sit, the only way to bring it back down is by backing off the idle adjustment.
Aside from the obvious air leak/carb culprits, could this be caused by an issue internally (piston rings, cam wear, etc.)? We did a compression test and found one cylinder to be slightly lower than the rest and performed valve adjustments which got it closer in line, so I don't believe that could be the cause but am willing to be proven wrong.
I took a short video in case this helps spark some ideas.
Thanks in advance!
