Author Topic: MPH vs RPM question?  (Read 614 times)
Offline Skyguyz
« on: July 04, 2022, 03:35:23 PM »
My 76 K6 has both aftermarket gauges. *Came with the bike..... :-\
Edit: Bike has a standard 17/48 tooth sprockets.
I know these are not accurate as I have tested the MPH vs a GPS speedo and it reads 6-7 MPH high than actual speed, (Typical of these things.)
My question is at what RPM should you see 50 MPH, 60 MPH & 70 MPH?
The bike seems to be reving higher than what the aftermarket tach gauge is showing.
On the inaccurate MPH gauge - 50 MPH, (actual 43 MPH) = 3000 RPM   60 MPH, (actual 54 MPH) = 3800 RPM
70 MPH, (actual 63 MPH)  = 4200 RPM  *I am sure the engine is spinning faster than what the RPM is showing?  Yes/no ?
Thanks in advance,
Sky
« Last Edit: July 04, 2022, 03:59:33 PM by Skyguyz »
Offline david 750f
  • 1976 CB750F
Re: MPH vs RPM question?
« Reply #1 on: July 04, 2022, 03:46:53 PM »
http://forums.sohc4.net/index.php/topic,157062.msg2010023.html#msg2010023
That for the 17/48 sprockets. Your results may differ with gearing changes  and non-stock tire sizes,
« Last Edit: July 04, 2022, 03:48:35 PM by david 750f »
1976 CB 750F
Offline Skyguyz
« Reply #2 on: July 04, 2022, 03:58:50 PM »
Thanks, I meant to include that info. Post has been edit to reflect a 17/48 tooth sprocket combo.
« Reply #3 on: July 04, 2022, 09:45:16 PM »
What is your front tire size?
Online PeWe
« Reply #4 on: July 05, 2022, 01:29:09 AM »
You can change sprocket sizes and rear wheel - tire diameter on that Excel sheet to get your calculated speed.
I have edited that file which I got on this forum around 8 years ago.  Added Kmh and later gearbox where 4 and 5 differ.
My K6 with 3.25-19 tire did not differ much when comparing speedo and laser/radar sign beside road complaining on peoples speed ;D
I think speedo showed +2.5%, absolutely below 5% too much which is good.
Important to find that laser/radar sign without any frantic braking i_iot in front  of you so you can test much faster which makes reading more accurate.
Streets with such sign has usually speed limit well below a good testing speed. 8)
« Last Edit: July 05, 2022, 03:29:01 AM by PeWe »
