Author Topic: A little clutch help please...?  (Read 873 times)
Offline Skyguyz
« on: July 10, 2022, 06:42:07 PM »
So, I am trying to help a friend who is having clutch issues with his 1975 SOHC engine.
FYI:  *I restore from the crank up, Kawasaki H1, H2’s, etc and most all other 2 stroke Japanese street bikes from the 1970’s. I could take apart a clutch basket for those bikes with high confidence. This is my first go with the Honda clutch. This Honda inner clutch basket is spinning freely with the 4 springs tightened in proper sequence and yet, the clutch is not “Biting” together the steels, (6) and the frictions, (7.) *See video.
I have checked the schematic on this clutch and see no parts missing. I measured the springs, (32.36 mm)  and friction plates, (3.67 mm) and
they seem fine. *I am using the homemade “Special tool" for the clutch nut...Sheesh!
*This must be a common rookie mistake with an easy fix?
Any pearls of wisdom is helpful and thanks in advance for for helping.
PS: Really hoping for one of the “AW-HAAA!” moments.     :D
Re: A little clutch help please...?
« Reply #1 on: July 10, 2022, 07:11:23 PM »
check the clocking of the splines; there are two right ways, and two wrong ways.
« Reply #2 on: July 10, 2022, 09:13:29 PM »
...and - that top clutch plate with the slanted cork blocks is backward. The slants should go the opposite way: flip the top one over. It must fling the oil out thru the grooves when spinning.
Offline Skyguyz
« Reply #3 on: July 10, 2022, 10:29:19 PM »
Thanks Scotty. I looked at the 2nd picture and it looks like it’s clocked correctly?
Offline Skyguyz
« Reply #4 on: July 10, 2022, 10:31:04 PM »
Thanks! I should have caught that as well.
Sky
Offline kaptainkid1
« Reply #5 on: July 10, 2022, 10:51:42 PM »
I just had this problems last week. The 1st pick of the clutch basket isn't sitting correctly and 2nd /3rd is correct.
You have to set the clutch plates correctly by rotating until it sits correctly. You won't have a gap on the back.
Sent from my SM-A526U using Tapatalk
1975 Honda CB750F Daily Rider
1974 BMW R90S Barn Find
1995 BMW R1100GS Dual Sport Daily
1996 Triumph 900 Adventurer Bobber
