Hey everyone,
Looking to get some guidance on what to check next on this issue I'm having on the headlight.
Bike is a 1974 CB550 and is a runner.
So far I've confirmed these are in working order:
- Headlight is GOOD. Turns on when connected directly to battery (HI/LO)
- Fuses are not blown (blade type). Voltage is present across all fuses
- ON/OFF switch on RH side looks to be working, gauge/dash lights will illuminate when switched ON and power off when OFF.
It doesn't seem like I'm not getting voltage to the blue and white cables leading up the headlight (unless you count 0.07V...) when switching between both HI & LO positions. The HI beam bulb stays off when HI beam is selected.
One thing I should mention is that recently my starter button no longer worked and the bike would not crank. I found out that the wire leading to the tiny contact plate in the RH switch corroded away from the plate. Re-soldered it and now she turns over when pressed.
This is the only major fix I carried out when wiring everything up, maybe it's related somehow? Headlight was working previously up until I went for a start.
I've only just pulled out the LH switch to do quick a check continuity on the blue and white wires and it sounds good. I will be pulling out that bracket on the HI/LO switch to do a bit of cleaning tomorrow.
Any information on what to check next and/or info from your own experiences would be appreciated!
Thanks,
Chris
